Question about Target Saws
What is the fuel mix? - Target Saws
  • 8,197 Answers
May I get the make and model # to help you more
Posted on May 19, 2011
What kind of fuel does a john Deere BH 25 gas leaf blower use that is a 2 stroke. And what kind of spark plug is used?
Spark plug is NGK BMR7A gap is .025 Fuel is any gasoline mixed 40 to 1 with 2 cycle oil.
Aug 26, 2016 | John Deere Garden
Gas mix is 3.2 oz per gallon what is size of fuel tank?
size of fuel tank immaterial. just mix 25 to 1 mix,and fill it up
Mar 18, 2015 | Garden
I have a 1993 Honda 125cc was told to mix gas but these oil in crankcase do I need to mix?
You would never mix any fuel and oil for the crankcase. If it is a 2-stroke engine, the fuel and 2-stroke oil will need to be mixed before entering the cylinder. Some engines have an automatic mixing setup - those have a separate oil reservoir for 2-stroke oil, but it will usually be a plastic tank, located nowhere near the crankcase. On a "4matic" engine, it fires like a 4 stroke, but there is no crank case, and the fuel needs to be mixed like a 2 stroke. What is the vehicle you are referencing? A dirt bike or street bike? It seems the CR125 and NR125 are both 2 stroke engines, so somehow the fuel needs to be mixed with 2-stroke oil. Can you take a picture of the crankcase oil cap?
Feb 04, 2015 | Honda Motorcycles
I don't know what fuel my leaf blower needs.
Almost every leaf blower uses gasoline mixed with 2-cycle mixing oil. Unless you have a larger, commercial model with a separate oil tank, you'll need to purchase mixing oil and mix it with your fuel. You can find mixing oil at PartsBuggy.com.
Oct 22, 2012 | Echo Garden
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
What is the oil to gas mix ratio ?:? stihl fs 45
If memory serves, Stihl recommends a 50 to 1 mix ratio on the gas mixture...( 2.6 oz oil to 1 gal fuel ) I usually run mine just a smidge richer and run a mix of 45 to 1... ( 2.8 oz oil to 1 gal of fuel ) I also add about 1/2 oz of "Stabil" fuel stabilizer to the mix (holds down gumming of the fuel and keeps things running sweet)...hope this helps... ;-D
Aug 08, 2010 | Garden
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Oil
40:1 fuel mix ratio is good for this model. you put gas in the upper tank and 2 stroke oil in lower tank the mix pump will do the mix, if you are not sure the pump is working properly, mix 4 ounces of 2 stroke oil into 1 gallon of gasoline and put the mix in the upper tank, it reach the carburator by gravity
Nov 20, 2008 | 2005 Honda Dio
Saws Logo
106 people viewed this question
Top Target Saws Experts
Tom Chichester
ray gallant
Are you a Target Saw Expert? Answer questions, earn points and help others
