Question about Canon PIXMA MP170 All-In-One InkJet Printer
Canon pixma mp170 all-in-one printer
My printer shows : "5100"on the screen and doesn't work.. The on-off button and a little white light on the left are flickering. What couls be the problem?
With best regards
Dirk van Noort
    Guru:
  • 1,463 Answers
Hi dirkvannoort
have a look here anything in the faqs section
Canon Australia - PIXMA MP170
riz.
Posted on Aug 16, 2008
SOURCE:
Tv powers on, see three birds in color then flickers and fades to white
The problem must be with its main digital processor board. It will be best to make it confirm. Contact any service technician. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | ViewSonic N1930W 19 in. LCD TV
My macbook dropped ..now battery cord doesn't light up very much and flickers... alot..? Is this an easy fix? Or is this gonna cost some bucks..? What could dropping the macbook have done to it
macbooks are very expensive to fix if you take them to the so called genie bar. so try a mall store to fix it or if money i no problem take it to the apple store.
Jan 15, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Canon ip2770 error 5100 and 5200
How to Reset Canon IP2770 Error 5100:
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps.
Turn off printer
Remove both the cartridges from the printer
Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
Return the cartridges
Turn on the printer.
Error will be removed
How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready for use.
Other Ways Reset Canon iP2770 error 5200:
1. Turn the printer, and printer will look normal.
2. Run the printer for printing documents or print test, then the 5200 error will appear.
3. Jump unplug the power cord without pressing the on-off
4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
5. Unplug all cartridges and leave the lid remains open
6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
7. Replace the cartridge, and close the correct
8. Your printer will return to normal. (Source: from all existing sources)
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 27, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
Error on screen 5100 color light &
I just went through this. My problem was that I had something obstructing my print cartridge. I took the back off with 3 screws, then the side panel (on the cartridge side). this was real easy, take the trim off and there is one screw, then find the little arrows that show where the tabs are that slide into the side of the printer itself. I used a flat head screw driver to unsnap them. Once open, I tipped my printer side ways and saw the object in there. Put it back together and now it works.
But the problem you are having could just be as simple as a loose cartridge. Take the cartridges out and put them back in making sure they snap in.
Good Luck!!
Regards,
Ron
Mar 22, 2011 | Canon PIXMA MP470 All-in-One Printer
Canon MP560 Gets error code 5100
Hello and Welcome
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Canon MP560 All-In-One InkJet Printer
The printer shows error code 5100 I think it has
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Good Luck.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
I have just instal my new pixma ip1300 printer but when i try to print it does,nt print and service error 5100 shows on my screen .
5100 says the carriage with the inks can't move right to left properly. Possibly grease that needs to be wiped from the encoder strip, behind the carriage, and one customer left the white plastic tray over the hole and stopped the carriage. Look for anything inside that would stop the carriage from moving freely. Also under warranty..so free service
Jul 23, 2009 | Office Equipment & Supplies
Blue flickering screen
What kind of motherboard/computer is it? Is the video onboard, PCI or AGP?
Aug 21, 2008 | Acer Aspire 5100 Notebook
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Dell Dimensions 5100 Power Button
The power light is tied to the Mother Board and therefore it could be an issue with just about anything on the PC. Here is the trouble shooting documentation and the link should bring you directly to what the various conditions of the power LED mean.
There is also a detailed listing for the HD light as well as some diagnostic lights (if your paticular variation is equiped)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1114432
Nov 22, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Canon PIXMA MP170 All-In-One InkJet Printer Logo
120 people viewed this question
Clive
Clive
old marine
old marine
Ekse
