NO SOUND ON MY CPU THE SYSTEME NOT WORK HOW TO SOLVE THIS PROBLEME
  • 407 Answers
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
I can't able to hear sound from my system.This is because the speaker (sound device) present inside the CPU was not connected or fixed. Though i know what's the problem i can't able to solve....
You can download the audio and device drivers for your computer from the manufacturer manufacturer's WEB site.
I cannot give you the link to the manufacturer manufacturer's WEB site because youhave not provided me with the details of the make and model of your manufacturer.
Jun 09, 2011 | Computers & Internet
When i plug to the cpu monitor cut off the power and green light is blinc
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Dec 31, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
DX 11 GPU'S
well 1st of all the DX 10 and DX 11 means the directx versions, well mostly cards run the games with uper version cards but some details are missing. well i had a dx 9 card and run a dx 10 game but some graphics were unavailible like decals and paintings on the walls etc,
2ndly the CPU requirement is not for the graphics these are for the system files and audio files to be process. and the GPU works only for Graphics. well i had a experience where i have a strong card but low system. but the problem was with the sound ... the game was prototype and the system was pentium 4 and required was dual core. my card was double the power that required for the game graphics work fine but the sound was breaking due to low CPU.
Hope that answers the question
Dec 27, 2009 | Computers & Internet
Varying Fan Noise
cpu fans are smart fans it works according to processor's temprature. more processing of cpu makes fans speed faster...slowing down the speed of cpu fan may affect your cpu's performance
Sep 24, 2009 | E-Machines eMachines Desktop PC
Same prob
This problem cannot be solved by anyone but a trained technician.
It will liklely requires one of the following repairs
1) new motherboard
2) new CPU
3) New CPU fan
4) new ATX power supply
This is my honest opinion after 100+ PM repairs personally.
best of luck,
Sagacious1
Aug 07, 2009 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
No display but cpu fan is working condition
check the connection of your video card, this is the common problem of cpu's specially if you are moving from one place to another. try to uninstall the connector of your monitor to the video card. if you have an extra video card try to replace the existing then power on. loose connection of your video will give you a rapid beep sound. if you are using the on board vga you try to install a video card or try to tighten up the connector.
Oct 24, 2007 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
