Question about Nokia 6700 Classic Cell Phone
How to access my sim card - lost my manual - Nokia 6700 Classic Cell Phone
THE CELL STOP RECIEVING SIGNAL IN THE DEFUALT SIM. I CAN NOT CALL OUT OR RECIEVE CALL ON THE DEFAULT SIM. EVERY OTHER FUNCTIONS STILL WORKING PERFECT
6
SIM selection key
In Idle mode, switch between SIM cards; Access the SIM
cards management menu (press and hold)
switch SIM cards automatically
1. In Menu mode, select Settings ? SIM cards
management.
2. Select SIM auto switch.
3. Press <Change> to activate the auto switch feature.
4. Select a SIM card and set the starting and ending
time to switch to the SIM card.
5. Press <Save>.
6. Repeat steps 4-5 for another SIM card
Samsung GT C3222 User Manual
hope this helps
Mar 14, 2016 | Samsung GT-C3222
Tip
What is PUK code. How to get this?
A Pin Unlock Code (PUC) or Pin Unlock Key (PUK) is used in GSM mobile phones and some smartcards to unblock a blocked SIM card.
The basic of PUK code is,
  • SIM cards have their own security
  • on startup SIM cards ask for PIN code (4 digit)
  • If user enters it correctly then its accessible
  • If user enters it incorrectly 3 times (in some 7 times) PIN code is blocked. To stop brute force attempt.
  • Blocked PIN code is unlocked through PUC (Pin Unlock Code) or alternatively called PUK Pin Unlock Key which is 8 digit.
  • If PUK is entered correctly user sets new PIN code and SIM is accessible.
  • If PUK is entered incorrectly 3 times, then SIM is no longer usable or accessible and any data in it is lost.
  • Sim card security is managed by their providers which are usually network companies like vodafone, 3G, Orange and Virgin or T mobile etc... (Whatever is yours like U-Fone, Warid etc....)
  • NO ONE else can give PUK code. YOU HAVE TO ASK YOUR SERVICE PROVIDER/NETWORK for PUK.
on May 16, 2010 | Cell Phones
My iemi number has been blacklisted
In my experience, with AT&T and TMobile, (sim Card) carriers, you can put another sim card in your device, and it will work.
However, when you make a claim via insurance for a "Lost or Stolen" phone, they lock the device itself to prevent thiefs from accessing all your vital accounts Ex: Facebook, Bank, Etc
Feb 09, 2014 | Cell Phones
My Laptop is Lenovo B460, it has a sim card slot but when I insert the sim card from my broadband to the slot, I can't access the services. Can anyone help me?
Ok, I stand corrected. I never knew this technology existed. I looked at your manual and it indeed shows a sim card slot. The manual also gives instructions on how to insert it and what you have to do to make it work.
Below is a link to your manual.
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/B460/Lenovo%20B460%20User%20Guide%20V1.0.pdf
May 08, 2012 | Computers & Internet
My smart roaming sim lost its signal..i dont know why but still it has a remaining balance..what should i do??
You can powercycle your phone. Turn off phone,remove the sim card,memory card, and battery. Wait for at least 5 minutes then after 5minutes,you can put back the sim card,memory card at battery. Try to check if your roaming card will again work. If this doest work you need to contact smart telecommunications and ask them to deactivate then reactivate the roaming of your sim. Because if your sim wont work,there will be no access for you to retrieve the load of your sim.
Dec 02, 2011 | Cell Phones
Entered wrong access-code three times. SIM card locked. I need my forgotten PUK-code.
the following codes are provided by the network operator:
-pin code
-puk code
both of these codes are provided when you purchase a sim card and are usually written on the sim holder or on the provided booklet.
if u have the puk code, then u can enter a wrong pin multiple time and then the sim card will ask you for the puk code which then u can use to unlock the sim.
if u lost both the sim and puk, then the only way is to contact the network operator to give you a new sim card.
Don't try to enter a PUK code without knowing the right one.
hope this helps
Mar 08, 2011 | Cell Phones
SAMSUNG CORBY PHONE LOCK CODES LIST,SECUTIRY CODE I LOST MY SAMSUNG PHONE MANUAL...SO PLZ HELP ME WITH ALL THE CODES USED TO LOCK MY ITEMS
hi...
here are the details
For PIN
When using the phone for the first time or
when the PIN requirement is enabled, you
must enter the PIN supplied with the SIM
card. You can disable this feature by using
the PIN lock menu.
For PIN 2
When you access a menu requiring the
PIN2, you must enter the PIN2 supplied
with the SIM card. For details, contact
your service provider.
Jul 16, 2010 | Samsung Lands Phones
No network access
my noikia 3110c flashing complited but ui setings faild why?
May 19, 2009 | Nokia 1100
Unblocking My Sim Card
Either you need to put a code in the phone to accept any new sim card or the the phone sounds like it has been reported lost or stolen or the previous sim card had the wrong pin number inputted causing the phone to lock and then the right PUK number was not entered. If you want to run to the expense of buying a serial cable for your phone I can pinpoint where you can get software for samsung phones. Look at my profile at mail me. Hope this helps.
Sep 29, 2008 | Samsung SGH-E350 Cellular Phone
I cannot get a manual download for my iphone
i cant use my sim card, how can i get to access and use my sim card?
Aug 03, 2008 | Apple iPhone Smartphone
Nokia 6700 Classic Cell Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
