Question about Datamax DMX-I-4212 Label Printer
The printer can not print at all.But every thing is ok.
  • 1,179 Answers
It's a thermal printer, the printer therefore needs to get hot to heat the paper and in turn print the document. The paper changes form due to heat.
Check that your printer is getting hot. Also try a newer roll of paper.
If the paper feeds through and it gets cut off, then the heater needs to be repaired/replaced.
Claim warranty support if you can.
Take care!
damnor01
Posted on May 19, 2011
I have an x7170 and the color printing is streaked. I just put in a new cartridge and it is doing the same thing...
Try this approach instead:
  1. From the printer operator panel, press Setup button > and then press Ok.
  2. Press the up or down arrow button until Clean Cartridges is highlighted, and then press OK.
  3. Press OK again. A page prints, forcing ink through the print cartridge nozzles to clean them.
  4. Print the document again to verify that the print quality has improved.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
Good day, i have a 4730mfp. it does not print colour correctly, the print out appears faded like the printer is out of toner, even after all toners are changed.
First thing to try is this, please go to control panel on the printer and to aministration menu. Scroll down to troubleshooting and find the PQ troubleshooting option and press ok. This will print a series of test prints. If these prints look OK then likely you have an issue with your driver. If they are faded, the second thing you need to do is check to make sure that your firmware revision is current. On the config page that prints with the pages just printed above, look on the upper left for firmware revision. Current version is 46.300.0. Download from here and install following the instruction in the readme file. Did it print OK before changing cartridges? If you installed remanufactured or 3rd party cartridges, the toner will not always provide the same quality of print.
Mar 16, 2011 | HP Color LaserJet 4730xs MFP Printer
After repacing cartrideges --it constantly states to press enter to allign cartridegs--and the printer will not print
I have the same printer and it does the same thing... make sure you have paper in and click the ok button on the face of the printer. It will print out a pattern, put the pattern upside down facing back in the scanner and hit ok again. This will align your cartridges and allow you to print once again.
Oct 10, 2010 | HP PSC 2175 All-In-One InkJet Printer
Just changed the yellow cartridge. The printer says it's full. No ink. Same thing with last cartridge. Tried deep cleaning.
Ok I understand the printer says its full but are you saying your computer says no ink? or that it prints no yellow ink?
Ok assuming you mean that it prints no yellow ink, the culprit ususally means that the print head needs replacing! Call Canon with your model and you can buy the part for new print heads for your printer
Mar 16, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printer feeds blank pages.
often in the Printer properties, there is a tickbox, to feed a blank sheet between print jobs. this is to assist in keeping print jobs seperated on busy printers.
Here is the way to change the setting on a single print job:
  1. Click the Start button
  2. Point to Settings
  3. Point to Printers (Windows 2000) or Printers and Faxes (Windows XP).
  4. Right-click the HP LaserJet driver you plan to use (2420)
  5. Click Properties .
  6. On the Advanced tab, uncheck Separator Page.
  7. Click OK to return to the Advanced tab.
  8. Click OK to save the settings.
Making the change a permanent thing For All print Jobs on this printer:
  1. Click the Start button.
  2. Point to Settings .
  4. Right-click the HP Printer you want to correct the settings to.
  6. On the Advanced tab, click Printing Defaults .
  7. Change any of the settings on the tabs. These settings become the defaults for the printer.
  8. Click OK to return to the Advanced tab.
  9. Click OK to save the settings and to close the printer driver.
Sep 23, 2009 | HP DeskJet F380 All-In-One Printer
I hve a installed a new hp print catridge but it deos not print
It asks you to align it. Press ok. The printer will print off an alignment page, then you have to run it through the copy part of your printer. Then press ok, and it will run through and line things up for you.
Apr 15, 2009 | HP Officejet 4215v All-in-One Printer
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printing problem
Well, as I dont know what exactly youre doing I will advise you to do the stantard process:
1. Uninstall the printer completely (COMPLETELY)
2. Copy ALL the document and paste it over a new one (WORD, PUBLISHER... same thing) just open a new document and paste all the text and save it with a different name.
3. Restart the computer
4. Reinstall the driver again and make sure it is OK by printing a TEST PAGE...
IF OK and the test page is OK then print your document.
IF NOT 1: the test page does not comes out OK, then you have a problem either in the printer driver or the printer mechanism (cartridges maybe, try replacing them for originals) if this way thing still bad, you have no better choice than take the printer to a technician as I assume your are clueless in repairing printers.
IF NOT 2: the test page comes out OK and the document does not, (MAKE SURE YOU CHOOSE THE RIGHT PRINTER inside "print options") the problem could be your computer and not your printer.
IF NOT 3: it would be very rare, but you could have a problem with the spool service (the windows service that manages printing matters) but in this case nothing shoud be printed ok. So if the test page is ok, the problem is NOT your printer and you should look for the problem in your computer or your operative system.
Best luck!
Jun 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
No text
Check that your black ink cartridge has ink inside, eventually try a new cartridge , as ink may have dried up in old cartridge.
If you use a new cartridge ensure you removed cellotape from cartrige.
If cartridge is ok, then it is printer nozzle/head for black ink.
In this case do nozzle check / head cleaning in printer tools a couple of times.
If problem persist you may need to check and clean printer's head with cotton and solvent.
regards
Mar 20, 2008 | Computers & Internet
Datamax DMX-I-4212 Label Printer Logo
90 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
