Clock is one hour fast - Computers & Internet
  • yadayada
    yadayada May 19, 2011
    What operating system do you have?
    Scholar:
  • 61 Answers
To change the clock time, just right click on the clock in the bottom right. Then go to Adjust Date/Time. A window should open and there should be an option to Change Date/Time. Click on that and a new window opens up. On the right of that window is the clock. Just click on the hour to highlight it and then click the down arrow to put it down one hour. Press ok and your clock is fixed.
Thanks for using FixYa!
Posted on May 19, 2011
Set the clock on Eclipse CD3414? step by Step
Turn [SEL] button to select CLOCK ADJ.
Press the [SEL] button. The clock adjustment mode is activated. Turn [SEL] button to display the item to be selected for adjustment. Hours, minutes or exact hour will be switched each time the button is turned.
Press the [SEEK /FAST ] button. [SEEK ] button: Turns the time forward. [FAST ] button: Turns the time back. To set the clock to 0 minutes, 0 seconds (an exact hour), press the [SEEK /FAST ] button.
For example: At 3:29: Pressing the [SEEK /FAST ] button returns to 3:00. At 3:30: Pressing the [SEEK /FAST ] button advances to 4:00.
Press the [RTN] button. At this time, other adjustments can also be made in Function Mode. 6 Press the [FUNC] button to exit Function Mode.
Also, you can read the manual here:
http://www.eclipse-web.com/us/download/manual/manual/pdf/CD3414(1-1455A).pdf
Jan 27, 2017 | Cars & Trucks
How do I set the clock in the radio?
Typically, you have to hold down a "Time" or "Clock" button, then press either a fast or slow button and hold it until the display reads the correct time. Some models have hour and minute buttons instead of fast or slow, and a few have a slide switch that you move to the clock adjust position (it would also have an alarm set position) before the hour/minute or fast/slow buttons are enabled. Some clocks reset to 12:00 AM if you hold Clock, Fast and Slow all at the same time. You'll just have to experiment a bit to find out what works on yours.
Jun 25, 2015 | Audio Players & Recorders
How to set clock jvc kw-xc770 car stero
1 Press SEL for more than 2 seconds. One of the PSM items appears on the display. 2 If "PSM CLOCK H" does not appear, press fast forward and up or fast backward and down repeatedly until it appears. 3 Turn the control dial to adjust the hour. 4 Press fast forward and up or fast backward and down until "PSM CLOCK M" appears on the display. 5 Turn the control dial to adjust the minute. 6 Press SEL again to finish the setting.
http://www.jvc.ca/manuals/KW-XC770.pdf
May 05, 2011 | JVC KW-XC770 CD / Cassette Player
I have model cd 3424 and cant set clock
This was taken from a radio similar to yours. Same brand but different model. Hopefully it'll help.
(Also the "SEL" button it talks about is a big round button/knob on the right of the unit.)
Setting the Time
This receiver uses the 12-hour display notation.
1 Turn [SEL] button to select CLOCK ADJ.
2 Press the [SEL] button.
3 Turn [SEL] button to display the item to be selected for
adjustment.
button is turned.
4 Press the [SEEK / FAST] button.
[SEEK] button: Turns the time forward.
[FAST] button: Turns the time back.
press the [SEEK / FAST] button.
For example:
At 3:29: Pressing the [SEEK / FAST] button returns to 3:00.
At 3:30: Pressing the [SEEK / FAST] button advances to 4:00.
5 Press the [RTN] button.
Function Mode.
Mar 02, 2011 | Eclipse CD3422 CD Player
How do i turn off demo mode? And set the clock?
  • Press and hold (SEL) button
  • Then turn the control dial to set "Demo/Link" to off
  • Setting the clock
  • Press number button 4 (Clock). "Clock Hr" (hour) appears. Then, turn the control dial to adjust the hour.
  • Press the >>' /\ (fast forward button) to select "Clock Min" (minute). Then, turn the control dial to adjust the minute.
  • Press the >>' /\ (fast forward button) to select "24H/12H". Then, turn the control dial to select "12Hours" or "24 Hours" time display mode.
  • Exit from setting by pressing the (SEL) Button
Hope that helps, don't forget to vote.
Nov 16, 2010 | JVC KD-G820 CD Player
My sony radio alarm clock is too fast about 1 hour. i have moved in the philipines. but my alarm clock is working too fast; ie, it does not show the exact time (about 70-80 minutes) faster
alarm clocks works on frequency and not only on voltage.if it is original 110v 60htz and you trying with 220v 50htz supply then it wont work correctly
Jun 04, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
My clock on my compturer is half hour fast
Double click on your clock in the lower right of the screen on the task bar and correct the time.
May 20, 2010 | Computers & Internet
My clock on my desktop is one hour fast,how do I
Double clicking on the clock will open up the properties so you can change the time. Make sure the time zone is set right and that the daylight savings box is checked if you observe daylight savings time.
Mar 17, 2010 | Microsoft Windows XP Home Edition
How do you set the clock on sony xplod 100db+?
The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Jan 28, 2010 | Car Audio & Video
JVC KD G-120 Clock Setting
once you press and hold select and get 'Area' release the select button and go ahead and press on the fast forward button until you you see clock H(hour), to set the hour turn the volume knob, then again press fast forward button to select clock M(minutes) and again use volume knob to adjust the minutes. once you are done make sure to press select to save setting.
Apr 09, 2009 | JVC KD-G120 CD Player
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
