Question about Canon PowerShot SX130 IS Digital Camera
Memory card locked, how do i get it back so i can take photos?
  • 6,831 Answers
Hello
Thank you for using Fixya!!!
Before you try anything, try using another card. If the problem persists, try the suggestions below.
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on May 19, 2011
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
Accidentally switched my sandisk memory to 'lock'
Locking the card simply protects it from writes. It does not wipe out anything that was on it already.
If you're asking about a Memory Stick, there's a switch on the back. Slide it away from the "LOCK" position. If you're asking about an SD card, there's a switch on the side. Slide it toward the metal contacts.
Jan 29, 2013 | SanDisk 16GB Ultra II 15MBS Memory Stick...
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
My memory card for D3000 is locked but i checked the card, it seems like the lock is not there how do i sort this out?
Oct 19, 2012 | Nikon D300 Digital Camera
Cyber shot camera dscw350 cannot take pics read only memory card
Look at your memory card or stick.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. Memory sticks have a slide switch just below the contacts. Slide the switch away from the "LOCK" position to unlock the memory stick.
May 17, 2012 | Sony Cybershot DSCW350 Digital Camera
Memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Samsung ES10 8.1MP, card locked can't shot a picture
camera shows card locked when you insert memory card and can not take photos but without memory card it takes photos.even when you change memory cards it does the same.it says card locked.
Dec 25, 2010 | Cameras
Hi! I have a Canon IXUS 130, I just put my memory card in my computer and copied some photos on there, when I put it back in my camera, I cannot take any more photos as the 'memory card is locked'. This...
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 27, 2010 | Canon Cameras
Casio exilim 8.1 card is locked
Hi!
Can you check if there is a small push button on the memory card itself? It could that it is currently on write-protect mode.
Aug 29, 2009 | Casio Exilim EX-S600 Digital Camera
I have a Brand new camera, the cannon SD880.. I just got back from vacation and as I opened my camera it said memory card error, I then clicked the button to view my pictures and it said memory card us...
Try some photo recovery software to rescue the files on your digital camera memory card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Jan 04, 2009 | Canon PowerShot SD880 IS / Digital IXUS...
Canon PowerShot SX130 IS Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
