Question about Gbc Combbind C12 Binding Machine Black (7706171)
Just brought the GBC combbind C12 after punching a few pages. The machine will no longer punch slots in the paper. You can pull the handle down but will not punch. Nothing appears to be jammed.
2 Suggested Answers
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Sircle Corp SircleBind CI-1500e Electric Spiral Binding Machine Jam
Hi Karen,
I would strongly suggest you find a local service technician to help you with this problem as the only way to release the pages is to wind over the electric motor by hand. To gain access to the motor the safety panels will have to be removed. The motor should be able to be wound backwards to release the punches from the pages, this will ensure the punches are not damaged.
If you attempt this repair yourself please make sure the machine's power cord is completely unpluged from the wall socket, not just turn off.
Dec 04, 2013 | Sircle Corp SircleBind CI-1500e Electric...
Bindmate GBC has paper stuck
Pull out the papers slowly one by one starting from the page on top. They'll probably rip but it's the only way I've found to get them out (I've tried unscrewing the covers but the thing doesn't pop out). For the next usage only punch a max of 4 pages.
Oct 18, 2013 | Acco Brands Corporation GBC BindMate...
Cannot get the arm all the way up
this can be caused by excess paper stuck in the punch area. clean out all the excess paper, making sure to pay attention to the punch area. gently try to move the handle, it may take several tries to get the handle to move freely, make sure you clean out all excess paper before you use again.
Sep 23, 2013 | Swingline Swi-74650 Three-hole Punch - 3...
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
CombBind C450e binding machine. How did I get the top off? A piece fell off inside and I cannot get the top off.
the top is connected with 7 star shaped screws look in the back of the machine you will see the exact shape. in the back there are 3 screws then there are 2 more screws on every side under the dark grey lable on is located on the very bottom (lift the lable you will find it) to find the other 2 slide your finger on the grey lable you will feel a small round hole on the right side it is about a cm under the **** where the papers get punched and on the left side it is about 3 - 4 inches under that ****. Good luck
Aug 27, 2010 | Ricoh FAX3900L Plain Paper Laser
Handle of Bialetti Moka Express 10 cup...
There is a tiny pin at the top where the handle slides into a slot between 2 aluminum walls. That pin needs to be "punched" out. I used a nail and hammer, but a tiny nail punch might be safer if you have one.
Nov 26, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Are we able to get the Binding machine blades sharpened. We have an Ibico, Ibimatic-No 315468. Have had for about 5 years. Thanks
This product is now manufactured by GBC (General Binding Corp, part of Acco) and was replaced by the CombBind C150 - just FYI. The lower-end machines such as this seem to run in the range of $200 USD.
I have never heard of sharpening these "blades", as they are actually punches, and there are likely some 20 small, individual "blades" that are part of the system. You might check with a local dealer or office supply partner, to see if they know of anyone who could or would perform the service and what they might charge for it. I believe that if you could find someone to do it, it would cost more than it would to simply replace the machine. There does not appear to be a way to replace the punch mechanism (die / strip usually) in these models.
An example of a machine with interchangeable dies is located at: http://www.factory-express.com/Binding_Machines/WireBindingMachines/GBC-TL2900/GBC-wirebind-TL2900.html.
Obviously, this is a much higher-level (expensive) machine than the one you have here. But this is an example of the interchange concept, and associated costs.
So, this is a rather long way of saying, and trying to explain why I recommend that, you check with a local dealer perhaps, but plan to replace the machine. If it lasted you this long, the same level of machine should last just as well, and $40 US a year isn't too bad!
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 29, 2008 | Office Equipment & Supplies
Gbc Combbind C12 Binding Machine Black (7706171) Logo
366 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
