Question about Electrolux E23CS75DSS Stainless Steel
My Electrolux E23CS75DSS Stainless Steel fridge freezer is working fine hoever the panels are very hot to touch, is this normal
catriver
  • 878 Answers
SOURCE: Electrolux E23CS75DSS Noise
Hi Andy, I have had luck insulating the cap tube coming off the heat exchanger, going into the evaporator. If the repair man can wrap some mastic around the area where the cap goes into the evap, this may quiet it down enough. This is common on some models. Some people are more in tune to it than others. Give that a try. Catriver.
Posted on Jun 16, 2007
mikedurland
  • 481 Answers
SOURCE: Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Posted on Jul 10, 2008
  • 218 Answers
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Posted on Jul 25, 2008
philbran
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
SOURCE: Electrolux Fridge 2 Door, Electronic Panel Problem
there s three plastic boxes the size of three inches long and two inches high there,s a leak there
Posted on Apr 13, 2009
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I am having problems with the ice maker. The water freezes but it will not roll over. I have to pull the ice off of the tray the ice is made.
check to see if water despenser is despensing water slow that normal. replace water filter . it will work ok
hope it can help u
Jan 12, 2011 | Electrolux E23CS75DSS Stainless Steel
Freezer working fridge not cooling?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 29, 2010 | Electrolux E23CS75DSS Stainless Steel
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Ice dispenser not working
HI THE ICE MAKER IS NOT DISPENSING ICE NOT WATER
May 30, 2010 | Electrolux E23CS75DSS Stainless Steel
The water door panel doesnt work. Incl. the light, ice. It doesnt even light up when the buttons are pushed.
Did you ever find a solution? mine has the same problem and I appreciate if you can share your solution.
Oct 16, 2009 | Electrolux E23CS75DSS Stainless Steel
Kenmore elite freezer/fridge hot to the touch on the front.
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Jun 25, 2009 | Kenmore 63893 Stainless Steel Top Freezer...
Electrolux icon Stainless Steel Temperature issue
ok you have a defrost problem the freezer does all the cooling for all the unit both sides give me a few and ill give you the procedure for finding out which part needs to be replaced
Feb 20, 2008 | Electrolux E23CS75DSS Stainless Steel
Jun 16, 2007 | Electrolux E23CS75DSS Stainless Steel
Electrolux E23CS75DSS Stainless Steel Logo
21 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
