Question about Compass Sport & Outdoor - Others
Where can i purchase C Plath 41462 compass fluid
CVT TRANS IN O7 COMPASS DOES NOT SHIFT INTO 3RD OR OD
A CVT is just that, continuous. You will not feel the familiar gear change. They need maintenance just like conventional ones. Fluid changes etc. Is your Compass throwing codes? If so see a qualified repair source. Continuously variable transmission
Mar 08, 2018 | Cars & Trucks
How do I check my transmission fluid on my 2007 jeep compass
If you can't find a second dipstick under the bonnet then you will find it will be a sealed unit and can only be done where you get your Jeep Compass serviced.
Sep 30, 2017 | Jeep Cars & Trucks
I HAVE A DEN HAAN TRAWLER OIL LAMP. AM USING NON-DYED KEROSENE FROM A SERVICE STATION PUMP. HAVE TRIMMED THE WICK. WHEN LAMP GETS THE TULIP SHAPED FLAME IT IS A DULL YELLOW COLOR AND SMOKES ALOT. ANY...
You are using the wrong fuel! Center Draft lamps should use either "Low Odor Mineral Spirits" or "Kleen Heat" only. It will not smoke if the wick is level and the flame spreader is in place with the correct chimney. If you purchased it from Leihman's, ignore their recommendation for Kerosene. From experience I have found Center Draft's to smoke on Kerosene and not on Kleen Heat.
Nov 04, 2013 | Weems and Plath Den Haan Mini Trawler Oil...
2009 jeep compass
seven days left on the auction for the whole manual set.
http://www.ebay.com/itm/2012-JEEP-COMPASS-OWNERS-MANUAL-GUIDE-BOOK-CASE-SET-12-/330798373437?pt=Motors_Manuals_Literature&hash=item4d051e9a3d&vxp=mtr
Oct 14, 2012 | Jeep Compass Cars & Trucks
When is a compass in need of repair?
    • 1.
      When there are cracks in the dome.
      2. When fluid levels are low,
      creating a bubble or fluid is all together empty.
      3. The dial or card is
      discolored or yellow.
      4. When the dial begins to stick
      * follow these steps to test dial.........
      While dockside take note of the compass heading. Hold any magnetic object
      to the compass so that the original heading is deflected about 10degrees.
      Remove that object, and see if the dial returns to it's original
      heading.
      Repeat this several times deflecting the compass to both sides.
AdChoices
Jul 09, 2012 | Camping, Backpacking & Hiking
How do I check the transmission fluid 2007 jeep compass
how many quarts does a transmission holds if it empty
May 08, 2012 | 2007 Jeep Compass 2.0
The dampening fluid has leaked out of my compass. Can it be repaired economically or should I just replace it?
Hello, no it wouldnt be cost efficient to repair. A replacement if it is in a console will not cost a fortune. Hope that helps
Oct 17, 2009 | Compass Scuba Diving & Snorkeling
Right ocular has separated from the body on Navy One binocs.
Contact the manufacturer
Weems & Plath, Inc.
Attn: Customer Service
214 Eastern Avenue
Annapolis, MD 21403 USA
or weems-plath.com
Jul 11, 2009 | Navy One Binoculars
Steiner Commander Compass not working - possibly low of fluid?
Check this post for lens covers.
http://www.bluewaterweb.com/MarineHardware/Hardware.asp?
Feb 15, 2009 | Steiner Military/Marine 7x35
Sport & Outdoor - Others Logo
328 people viewed this question
Top Compass Sport & Outdoor - Others Experts
Bill Eager
Are you a Compass Sport and Outdoor - Other Expert? Answer questions, earn points and help others
