Question about Craftsman 20 hp 42 in. Deck Yard Tractor
I have a 42 inch craftman riding mower when i let out the clutch it stalls and another problem is that it wont turn over unless i jumo it it has a brand new battery and new selinoid
    Brigadier General:
  • 3,911 Answers
There are several safety switches which are all tied into a central relay which defeats the starting and kills the running, unless they are all in the correct safe running position. a lot of craftsman mowers have that same exact let out the clutch problem and it is related to a failure in one of those parts.once you get that issue resolved, the other issue may resolve itself.
Posted on May 19, 2011
Why murray riding mower wont crank when being jumped off
Some mowers have safety switches that unless you are sitting on the seat and the clutch pushed in they will not start. Not sure if this is the answer.
Jan 05, 2017 | Murray Garden
Why does the motor on my craftman riding mover stall when I let out clutch/brake?
Drive belt conditions? Wrong belt installation. Mower assembly will not turn by hand, so there are bearing and engine load problems? Clutch doesn't like the brake to be on?
Owner's manual trouble shooting? no manual
try manualslib.com
Mar 28, 2015 | Garden
Craftman lawn tractor 20.0 HP 42" electric start blades will not engage
Check for voltage at the electric pto clutch connector if 12 +volts is there when the switch is on then the clutch is bad; otherwise, you need back through the wiring to find the problem.
Aug 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor shuts off when clutch is engaged craftman 22 hp 50" mower
I had the same problem. My problem was something was preventing the blades from spinning, so the 1st thing you can do is check to make sure your blades turn, and test this while the mower is off.
While it is a pain, you can also take the deck out and check to see if this help and you are able to freely turn the blades. If everything is working properly, you should be able to turn the blades by hand.
In my case, I has a stick jammed into the belts and pulley, so when I would engage the blade, it would cause my mower to stall when it tried to engage the belt.
Hope this helps.
Dave
May 29, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
Just looking for a belt diagram for my 42 inch craftmans mower deck
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info. http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck!
Aug 13, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The mower will stall when I lift my foot off the brake.
If you have a gear transmission,you have some safety switches. One under the seat. One on the clutch -brake pedal. These switches work together to prevent accidental injury. One may have disconnected or a wire frayed. If one switch has failed it will shut the mower off.
Apr 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Jan 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Aug 27, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
93 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
