Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
I stored my lawnmower on an angle all winter. Yesterday when I tried to start it oil came out of the exhaust. Today it started with alot of blue smoke, of course. what's my next step?
  • 843 Answers
Just make sure the oil level in the crank case is OK, then just run it. The smoke will burn off once the muffler heats up, but it may take a while. The smoke is annoying, and not all so environmentally friendly, but it won't do the mower any harm. Just because the oil leaked into where it wasn't supposed to be, it doesn't mean that you have increased the ability for oil to leak that way. Good luck, Al K
Posted on May 20, 2011
Bourght petrol 471sp lawnmower with no manual it will not? put in oil and petrol.
probably the gasoline gummed up at bottom and needs to be cleaned. if the gas is not emptied when stored it can do this and will not start
Apr 08, 2015 | Garden
Trouble starting, blows smoke, high revs, fuel leak out of exhaust.
first push starting it was bad. sounds like a stuck exhaust valve. and I think you had a dead ignition coil causing 1 cylinder not to fire,and it was fill with gas ,and then you forcing it to start did more damage
Nov 07, 2012 | 1992 Mitsubishi Pajero
Champion 35 lawnmower hunts
Clean the air filter (foam type) in warm soap water then apply some oil soaked in, it will smoke afterwards for a short time. Or possible minor adjustment too the mixture screw on the side of the carburetor spring loaded. Allan
May 09, 2012 | Garden
Lawnmower stored for a year tipped up and all oil leaked out -- Won't start now.
You have most likely gotten oil on the coil, You need to remove the pull start assembly and you will see the coil/flywheel, check for any oil contamination which you can clean up with brake/carb cleaner.
Mar 04, 2012 | Poulan "Poulan" Push Mower
I stored my Briggs and Stratton Murray 4.5 Lawnmower at an angle and oil came out the exhaust.
Just let the mower sit on the level for a while. Then be sure to check the oil level before starting the engine. It'll probably blow some oil smoke, but then it should clear up and be fine. You should only tip your mower in one direction, ever. That is down on the handlebars; up on the front. This way, the fluids have no where to run. Also be sure the gas tank is not full or fuel will run out the vent in the cap.
Oct 09, 2011 | Briggs & Stratton Briggs Stratton...
Have argos xtreme lawnmower 123cc petrol 3.5hp last used oct 2010 and stored in brick shed for winter. Will not restart april 2011. It has petrol and petrol switch is on. The choke is out for cold start...
Stale fuel is normally the cause for bad starting after the winter, fuel has a very short shelf life before it goes stale, drain the fuel tank and carb float bowl, refill with freash fuel and try again
Apr 05, 2011 | Garden
I leaned my lawnmower forward (on its front wheels) when I stored it. Now the lawmower is sputtering when I start it...There is smoke coming out the side of it. It only runs properly if I lean it on its...
most likely you have oil on top of the pistons and to much has gotten into the intake and exhaust valves. remove the spark plug, clean it or replace it, than pull the starter rope several times to exhaust some of the oil inside. install plug and start the mower. it might smoke some but should clear up.
Nov 20, 2010 | Mtd 22" Yard Machine Push Mower
My craftsman 6.5 hp lawn mover oil leaaking and smoke coming ou
Smoke white or blue? = oil overfilled possibly.
Apr 16, 2010 | Garden
2005 nissan will turn over but will not start. Yesterday had strong smell of gas. Today it won't start
IS THIS A 2.5 IF SO MOST LIKELY IS CRANKSHAFT POSITION SENSOR SEE ALOT WITH SAME PROBLEM
Mar 19, 2010 | 2005 Nissan Altima
Low coolant and oil smells like gas. No white/blue
let your car idle go back to the tail pipe if it seems to be steaming alot , and or smells like antifreeze then you have a head gasket problem or a gasket leak alowing in directly into your engine
Apr 28, 2009 | 2002 Ford SVT Focus
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
608 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
