Error Message: Fuser door open - Office Equipment & Supplies
  • 313 Answers
You have to look on the sides of the printer where the door closes. Here it should be a mechanical sensor. Make sure that it closes properly to sense the door is closed. If it doesn't, it needs to be replaced. More exactly, it's a sensor underneath the fuser door activated by a plastic arm, which is difficult to see. This sensor has a spring arm against which the plastic arm pushes and you have to bent the spring arm out just for a second so that the sensor can activate by itself.
I hope I helped you!
Posted on May 19, 2011
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
502 fuser error. replaced fuser with same message.
Hello Dear ,
Open the door & pull out the fuser then you will see the 2 no of sencors situated left upper side below the front covel ,clean them with clean cotton your problem will be resolved .
Altough problem persists then if u r technical then open the fuser unit & remove the teflon u will find temp sencor it become dirty by which it also shows the said error clean them you problem will be resolved 100%..
Regards
jm
Aug 23, 2011 | HP LaserJet 4700 Printer
What is "fuser door open"
Fuser Door Open is the message on the display when it's powered on. I took the back apart, removed the fuser, looked all over. I couldn't see any kind of sensor, optical or mechanical that makes when the door is closed. There's an access plate with a blue latch below the fuser that makes an optical sensor and a mechanical sensor, but that seemed to be OK. It didn't seem like something that would be called a fuser door. So, I pushed on it where it made the mechanical switch and the printer hummed to life and the message went away. I took the fuser out and examined it. The metal brackets where the pivot parts were, seemed a little bent. I straightened them out, stuck it back in and that fixed it.
By moe who hasDell MFP 1850DN this might also help...
or Fuser Door Open
1. Make Sure the Paper Tray is Loaded Correctly With no Obstructions
2. Clear the Paper Jam in Tray 1 or 2
3. Clear the Paper Jam in the Multi-purpose Tray
Jul 05, 2011 | Dell 1815dn All-In-One Laser Printer
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Ricoh aficio sp 3200sf fuser door open error getting "fuser door open" message. opened and reclosed fuser door to make sure fuser door was closed. restarted printer. still get same message. what can i do...
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Jun 16, 2010 | Ricoh Multifunctional SP 3200SF...
I get an error message of Fuser door open
turn off printer pull out fuser unit turn on printer and turn off printer again replace fuser unit back and turn on the printer
Dec 14, 2009 | Dell 1815dn All-In-One Laser Printer
I'm getting an error message #010, what does this mean?
Hi, Barbara.
If error: 010-349 That is a fuser error.
Open the rear door. Remove and reseat the fuser.
If this does not work, you will need a new fuser.
If not that specific error, just let us know.
Hope this helps.
Sep 03, 2009 | OKI B6300n Printer
Turn on get error c0500 on a minolta ep4050
the error codes means Low fuser temperature during warm-up
Jul 06, 2009 | Office Equipment & Supplies
123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
Mar 19, 2009 | Lexmark C762 Laser Printer
99 people viewed this question
k24674
jasbo
jasbo
