Question about Mitsuba DV9002 Flash Media Camcorder
I need a manual for my dv9002 12.0mp, 8x i have all the parts just cant get it to work without following manual
  • 8,197 Answers
How do I assemble a crib I bought without a manual?
well, we cant even see the thing so a touch difficult
cant be that hard, lay the parts on the floor. There must be an obvious base, two long sides and two short sides. Only then have to work out the fasteners and basic orientation of parts.
Sep 22, 2014 | Baby Gear
User manual
HTC Windows Phone 8x: Need User Manual:
Hello.. Your User Manual for the HTC Windows Phone 8x has different User Interface for different Cellular Carrier Service Providers..
You should check with yours to get the correct menu steps to access what it is that you need..
Example PDF Links for HTC Windows 8x User Manuals:
https://www.att.com/support_static_files/manuals/HTC_8X.pdf
User manual Windows Phone 8X by HTC
Dec 18, 2012 | HTC Windows Phone 8X
Need list of compatible Graphics Cards for my ASUS p5s800vm Mother Board. Has to be 8x 1.5v Thank you!
Following graphics will work for you.
AGP 8X
ATI Raedon series video cards
NVIDIA geforce series cards.
Thanks
Nov 02, 2010 | ASUS P5S800-VM Motherboard
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
Can't tell what my DVD drive is capable of
The DVD drive is an 8X burner, not a ROM (read-only).
The laser lens may need cleaning.
Radio Shack has a CD/DVD laser lens cleaner ($13). It is an audio CD with a row of brushes. No chemicals involved. Read and follow directions.
It won't mess anything if not done correctly.
Best DVD media is Verbatim. Best price is found at OfficeMAX.
Oct 08, 2009 | Acer TravelMate 4202WLMi Notebook
Acer aspire 6920 18.4 inch screen! I cant get blue ray dvds
According to the ACER Aspire 6920 specs, it does not have a Blue-ray player only DVD CD R/W drive. Therefore it cannot play blue-ray movie disks.
The specs of the DVD drive are as follows :-
Optical Storage
  • Type DVD±RW (±R DL) / DVD-RAM - Integrated
  • CD / DVD read speed 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
  • CD / DVD write speed 16x (CD) / 8x (DVD±R) / 4x (DVD±R DL)
  • CD / DVD rewrite speed 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Jul 24, 2009 | Acer Aspire 6920-6422 Notebook
Problem with Video on motherboard Gygabyte 8VM533M-RZ
The answer is a definite YES. By definition of the AGP set standard, 8x gear absolutely must be backward compatible to 4x.
Any 8x card in 4x-only mainbaord, or 4x AGP card in 8x capable motherboard must and most definitely will work.
May 24, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Nvidia graphics card won't fit in asus ncch-dl motherboard
The NCCH-DL has the following slots:
1 - AGP-Pro 8x
(you can use regular AGP cards in here as well as long as you have the little plastic thing that comes with the mobo... you may even be able to without it)
2 - PCI-X
This is NOT PCI-E.
You CAN use regular PCI cards in a PCI-X slot IF the company that manufactured the card left the space between the little metal contacts... unfortunately, many PCI cards are made with the space filled in with useless plastic... I've heard you can cut the little space yourself and it'll work fine... I don't know why it wouldn't but be careful, and of course do at your own risk.
I currently use a regular PCI network card in this slot because the onboard LAN port only has Win64 bit drivers on the web site and it works just fine.
A PCI-E card will NOT work in this slot.
Generally speaking the PCI-X cards you are going to find are riser cards, network cards, firewire cards, and controler cards.
2 - Regular PCI Slots.
I think you know what PCI is.
May 03, 2009 | ASUS NCCH-DL Dual...
Hi i have big problem with my ViewSonic VX2235wm monitor
check did you insert external display card or using internal if not inserted then internal display card will not support above 600x800 if you want to work with high resolution then insert AGP card and reinstall drivers there are 4 type cards 1x,2x,4xand 8x you use 8x AGP card then select high resolution also you can look best movie and good support to 3D games
Nov 18, 2008 | ViewSonic VX2235WM Monitor
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Mitsuba DV9002 Flash Media Camcorder Logo
216 people viewed this question
Top Mitsuba Video Cameras Experts
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
