Question about Rotel Audio Players & Recorders
CD drawer only opens manually on my Rotel RCD 970BX, teeth are broken off on mechanism
  • 274 Answers
SOURCE: CD drawer will not open
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
Posted on Jul 16, 2007
SOURCE: Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Posted on Mar 04, 2008
killer_clown
  • 86 Answers
SOURCE: cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Posted on Oct 24, 2008
  • 88 Answers
SOURCE: Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Posted on Nov 05, 2008
SOURCE: request user manual for Sony RCD-W100 CD recorder
sony cd recorder rcd w100 not recording
Posted on Feb 05, 2009
The Cds get stuck in the unit; unit won't play and cd drawer won't open
HAVE YOU tried to open the tray by the pin hole on the front with a paper clip
Jul 07, 2015 | Sony RCD-W500C 5-Disc CD Recorder
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
I have a rotel rcd-1520, cd player. It hasn't been used much. It won't register that there is a CD, when I load the CD into the player. Any idea why?
the beam on the electronic eye might not be reading the disc...clean it as much as you can it might help...good luck to you
Aug 25, 2013 | Audio Players & Recorders
RCD-W10 Sony CD player/recorder left tray will not open
Two things generally make this happen. One is electrical and the other physical, First check to see if a light comes on when it is supposed to be working. If not, you'll likely need to get it back to the shop from whence you bought it. You don't say whether this item is new or you've had it some time. The other physical problem is a disc left in the drawer which is not 'sat' down properly, effectively jamming the tray. If this is the case you will see the drawer trying to open. On the front of the CD drawer you will see a very small hole (big enough for an unbent and straightened paperclip) that is used for manually opening the tray. The pin does not have to go in very far and only slight resistance should be felt before the tray drawer opens. If this does not work ........ back to the shop where they open it up and sort the problem. I do not encourage people to open electronic deveices thyemselves as ther are many delicate parts inside that could inadvertantly be damaged. Despite which you would be invallidating any gaurantee you have on the product.
Mar 15, 2011 | Sony Audio Players & Recorders
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
My CD drawer won't open on my TV/recorder,
The CD drawer have an small rubber inside that makes the mechanism inside to work, that rubber breaks down with the time and is the one that makes the drawer to come out, so if the rubber is broken it wont come out.
Dec 30, 2009 | Symphonic WF803 DVD Player/VCR
Broken control on CD player Rotel RCD9658X
Hello Fayeshep,
They are indeed beautiful machines...!!
I looked for service and customer contact
See the top & bottom of the ROTEC AU page (below)
Good luck & happy hunting...
Rotel Australia Home Theater Hi Fi and Custom Installation
May 20, 2017 | Rotel Televison & Video
Mar 03, 2008 | Audio Players & Recorders
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Stuart Slabber
Level 1 Expert
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
