Excellent video which shows how to access the spacemaker
Manual and more HERE
Post the model number for a better response
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hi, There are wires going from the main board to the surface lamp and turntable. They are thin orange, yellow and blue wires. I think the surface lamp is yellow and the turntable wires are orange. You should first try taking the bottom cover off. There are about 8 screws under neath and the bottom cover hinges on the back edge, just let it hang. You can now see the wires. Those wires short to the case where they go through from the main board to the lamps or turntable motor. You now have to move them away form the case. Sometimes they get pinched to the metal cabinet by the lamp socket area. Look for signs of pinched wiring there at the lamp socket or where they go through. Move them away, tape up the bad area. Also check this link if it helps:- http://www.premierrange.com/faq-lightingrangepilots.htm Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
This is simply NOT the issue that I posted. I am interested in gaining access to the TOP console on THE GE Space Saver -- IT IS A TWO OVEN UNIT -- not one & the switch is for lights in between the top & bottom. This suggestion is useless.
This simply is not an answer to the question I asked. My question has nothing to do with a door light on a single oven.
Let's start where I began W GE Spacemaker [JV HP63V OK AD] -- DOUBLE oven [small top -- normal bottom] with 4 burner stove top in between.It is a hi end 1988 model -- I need to get at a dead switch in a panel at TOP RIGHT [next to sm. oven] it has [in order top to bottom] a clock, two oven temp controls, 4 X burner controls,THEN across the bottom lite switches -- one id dead. It has a hinge on the BOTTOM but I cannot free the panel to open it. THANKS!!!
Not this stove --note --the stove is ELECTRIC -- the link describes a pilot. Sorry !
2 years later... Did you get an answer? I have the same issue with mine. After some cleaning, my son - who is taller than me - found a single screw dead center of the control unit on top. Remove that screw, the unit hinges away for access to all controls.
