Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
How do I make my hand held stairway nozzle to extract water, it only puts down water, but won't **** up water, help
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: puts solution down will not extract
On the inside of the recovery tank lid, the foam filter, if it is all of the way up to the top of the lid, lower it to leave about a 1/4 in. gap. The red filter at the bottom is clogged. The lid is not locked onto the tank, these are the main reasons when you don't have suction.
Posted on Feb 12, 2008
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Vacuums
My bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Sep 20, 2012 | Bissell 1716 SpotLifter PowerBrush
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
O-Cedar Pro-Mist trigger doesn't work
This person is asking about an O'Cedar Pro Mist Mop. Not a vacuum or steam mop...
I too have problems with the pro mist handle not working... I called the customer care line at 1800-543-8105 and they are replacing my mop for free. You can also try to take it apart and fix it yourself, but I did that and I cant remember how it goes back together! lol Basically a spring comes loose from the pole inside of the mop handle, and that is why there is no tension in the trigger.
Feb 19, 2012 | Vacuums
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
I took my nozzle apart on my hoover steam vac because it leaked water all the time, now I cannot get the back together
The Hoover SteamVac is an upright, self-contained carpetcleaning machine. The machine features five rotating brushes and on-boardstorage for a hand-held upholstery tool with an 8-foot hose. But itis not that much difficult to re-attach the Hoover SteamVac nozzle. Here, a weblink, with full procedure and diagrams, which will help you to re-attach iteasily - http://hoover.com/file/624/. Hope this will help you. Good Luck.
Aug 18, 2011 | Vacuums
My Bisell Proheat will not dispense water to the floor but it will dispense through the hand held tool.
check the little nozzle that the water sprays from and see if they are plugged if not your element chamber may need to be cleaned
Mar 02, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Clearview 1669
Take out the 2 long screws with the nuts on them, then furher down just beneath the hose wrap asm, there are 2 more screws to remove. Put the top part of the handle off, lay the handle down, on the front, at the top and in the center is a tab, push it in and pull the top half of the handle away from the bottom half. Then you will see the heater, don't mix up the hoses after you are done.
Jun 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
