Question about Car Audio & Video
I have 2 mtx thunder 6000 12inch subs. one works great but the second one act's like a speaker wire is crossed but all the wires are right. i can hook both subs to the same channel and the first one sounds great but the second one just wont work right.
  • Rojo25 May 19, 2011
    i can hook the exact type of sub up to the same channel and it works fine but the other subwoofer doesnt.
  • 407 Answers
May have a blown channel in your amp.
Posted on May 19, 2011
  • Michael Spreafico May 20, 2011
    Then that is a bad speaker.Good move on your part to try the other speaker too.
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
I need to know how to bridge the mtx speaker 4500
I assume you mean wiring a dual 4 ohm voice coil sub to a 2 ohm load, right?
Follow closely
Go from positive of the source (amp or positive post in box) to the positive of both voice coils.
Then go fromt he positive of the source (amp or positive post in box) to the negative of both voice coils.
You will be running two length of speaker wire for this. It's the easy way and makes sure that each voice coil gets clean power.
This is called a parallel set up and will bring two 4 ohm voice coils to a 2 ohm load.
Happy Wiring
Aug 14, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
What is Positive and what is Negative
Hi Mason.
Are the positions colour coded in any way?
Red = Positive
Black = Negative
I've looked at some photo's from the website and at a guess I would say that yours are the push on crimp types, so no colour markings.
Have a look at the pdf wiring diagram they supply here as it may shed some light on things:
MTX Thunder US-XT12-44
I've looked over loads of forums but none seem to mention the wiring of these subs.
Understandably you want to get this right as they are a very nice set of subs when they're up and running.
If all else fails try looking at the MTX contact list and ringing one of their supported dealers for more info.
Regards
Mike
Mar 21, 2010 | MTX Thunder 6000 T61044A Car Subwoofer
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
WIRING A DUAL VOICE COIL SUB.
Just wire one voice coil each into left and right rear respectively, in series with the original rears or if this is too quiet, wire both voice coils in parallel together and connect as per original single coil unit.
As they are 4ohms each they can simply be connected as simple speakers on each rear channel output, since thats exactly what they are, capacitors are used inside to make them react to bass frequencies only. Wiring them up is no different to wiring up a pair of 6x9's.
Oct 24, 2009 | MTX Thunder 4244 Car Audio Amplifier
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
