I have a Biostar Motherboard K8M800-M7A and i just recently bought a kingston ram memory 1GB 400mhz KVR400X64C3A. Everywhere i look for on the internet says they are compatible but i dont get them to work. Any suggestions? thanks in advance.
  • cesarflip87 May 19, 2011
    Thank you for the quick answer. I can't understand how it is possible that both memorys (crucial and Kingston) with the exact same specs, one does work and the other doesn't. It makes no sense at all. Is there any modificaton that I can test altering Dram configuration on the bios ?
  • 367 Answers
You are correct, this motherboard can use either 333mhz DDR (PC2700) or 400mhz DDR (3200) chips.
You may have a bad chip. Also make sure you are not mixing this chip with another of another speed. Its not good practise to mix 333mhz and 400mhz though some motherboards will still work like that.
Your best bet for compatibility is crucial DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 128Meg x 64 •
Personally I have had bad luck with kingston ram myself.
Chris
Posted on May 19, 2011
  • 2 more comments
    Thanks for your quick answer. I can't understand how two memory with the exact same specs, one works and the other doesn't. Is there any modification that I can test altering dram configuration parameters on the BIOS ?
  • Chris Larocque May 19, 2011
    Your default settings in the bios should be all you need. You could try updating your bios if there is a new version out. Sometimes that helps. Also, have you tried putting the chip in the other slot?
    Chris
    Both slots and still nothing. Upgraded the bios earlier and still nothing. It must be the chip. I already talk with the salesman to see if he can replace it for another model. I will let you know.
    Sounds good. I hope you have some success.
    Cheers
    Chris
My biostar k8m8oo-m7a powers up but has no video
I screen is simply black, it is probably the RAM
Remove the RAM, gelty clean it off and reinstall
Dec 19, 2012 | Biostar K8M800-M7A Motherboard
Why does memory upgrade for biostar k8m800-mam2 motherboard cause memory error beeps?
I would verify that the memory you're using is actually working properly.
Try to boot to the new stick and see if it works.
If not, it doesn't work.
If it does, you may need to replace the original stick with the same stick that you are trying to use now.
Use this site as a guide.
http://www.crucial.com/store/listparts.aspx?model=K8M800%20Micro%20AM2&Cat=RAM
Dec 22, 2011 | Biostar K8M800 Micro AM2 Motherboard
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Biostar k8m800-m7a continuously beeping without booting up, the monitor says no input signal
    memory error
    Verify your memory module, eventually another module tries.
    If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
    Feb 26, 2011 | Biostar K8M800-M7A Motherboard
    Can biostar k8m800 m7a 754 run windows 7
    The processor will run windows 7 but may not be very fast.
    Look for the correct driver for the m/b at BIOSTAR.com
    Dec 27, 2009 | Biostar K8M800-M7A Motherboard
    Monitor don't go on
    oh you meant monitor doesn't come on.
    if its a KNOWN good board next look to the power supply, video card, and ram.. lastly the CPU they fail less often but CAN fail.
    Aug 06, 2009 | Biostar K8M800-M7A Motherboard
    Driver
    go www.biostar.com.tw if your mb is biostar... otherwise go whatever site your motherboard`s label indicates.
    I could link you directly but you have posted two models (K8M800-M7A and P4VM800) and the second one is not in the biostar list...
    Aug 11, 2008 | Biostar K8M800-M7A Motherboard
    Plan to upgrade
    This motherboard does support Vista.
    May 15, 2008 | Biostar K8M800-M7A Motherboard
    Dispaly driver vga vr.1.0
    what comp[atible video driver for toshiba dynabook satellite 2270 because i dont know what compatible driver for this
    Apr 13, 2008 | Biostar K8M800-M7A Motherboard
    Computers & Internet Logo
    77 people viewed this question
    David Payne
    David Payne
