Question about Disney Interactive Pirates of the Caribbean: At Worlds End for Nintendo Wii
My game keeps freezing in the same spot and makes a high pitched noise.
    Problem Solver:
  • 10 Answers
This is usually due to a damaged disc. Take a look at your disc, and see if it is cracked, scratched, smudged, or chipped. If so, you may need to get it cleaned, or buy a new disc. If it is due to scratches, then you can use toothpaste to fix it. just apply a small amount of toothpaste to a soft cloth, and wipe gently from the center of the disc, outwards. You can also clean the disc in a similar manner, if you just do not apply toothpaste.
Posted on May 19, 2011
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Squeeling noise, very rough idle (sometimes stalling), no engine code
Rough idle / stall at idle Check for vacume leaks & split intake tube or loose clamps on intake. Noise put spot of grease on drive belts if noise goes you may need new belts or a tighten up.
Jun 16, 2012 | 2004 Ford Freestar
While playing games the wii makes a high pitched sound
That's the capacitors inside the system. When capacitors aren't solid state they will make a high pitched noise while under load.
Mar 04, 2011 | Nintendo Wii Console
My washer has started making a high-pitched noise while spinning.
Hi
to chek what is wrong follow the bellow instruction....
Check the motor bearings
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer.
Check for Obstructions
Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket.
Check for Grease Spatter
A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing.
Check the Drum for Irregularities
Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Washing Machines
Turtle beaches make a crakle sound
If you unplug the chat-controller cable from both the headset and the controller, then play the game soundtrack through the headphones, do you still hear the high pitched noises, or do they go away?
If they go away, then a replacement chat-controller should fix the problem.
If the noises do not go away, then your best bet would be to tell Turtle Beach tech support about this --- support@turtlebeach.com.
Sep 13, 2009 | Microsoft Turtle Beach X4 Dolby Digital...
Its crashing in the middle off games!!
This is interesting . let me guss just before it happens somtimes gets white or green vertical lines.
I know what the problem is , but im surprised to hear its happening with newer consoles.
The Problem ,there are about 9-10 solder ball just under the hot spot on the G.P.U.
after it seem a relatively short period of time (usage) they start to get thermal fatigue
and fracture open ,and cause a long list of problems .Im afraid the only way to fix
it will void the warranty.
Recommendations :Return it to MS and get a replacement
Sorry this probably wasn't much help .
Jul 03, 2009 | Microsoft Xbox 360 Console
High pitched squealing and now not working
Seems like the wii froze. Try other discs and if worse comes to worse send the wii to nintendo
Dec 31, 2008 | Nintendo Wii Console
High pitched noise comin out the sub
You may have a ground loop issue. Make sure your ground lead is as short as possible (<1ft, if possible) and that it is mounted to a nice, clean (unpainted) spot on the vehicle. If you have multiple amps, try and ground them to the same point.
Mar 07, 2008 | Fusion FEW12PK Car Subwoofer
High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Jun 11, 2007 | Toshiba 27A41 27" TV
Disney Interactive Pirates of the Caribbean: At Worlds End for Nintendo Wii Logo
188 people viewed this question
Top Disney Interactive Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Joseph Hoffmann
EnergeeUK
Level 1 Expert
Are you a Disney Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
