Used to be able to go into Photofiltre and now says: Photofiltre.exe-Bad Image The appication or DLL C:\system32\msvfww.dll is not a valid windows image. Please check this against your installation diskette.
  • 177 Answers
Under Add/Remove Programms choose repair then reboot and re start Photofire. The Application might have become corrupted.
Posted on Aug 14, 2008
SERIAL NUMBER
1) Run wga tool to check - genuinity , type of copy (OEM/Retail)
Link :
http://go.microsoft.com/fwlink/?linkid=52012
Shortlink :
http://downloadwgadiagtool.notlong.com
2) Check date/time
Do the below troubleshooting steps in safe mode
3) Check the "value data" for the following keys under HKEY_CLASSES_ROOT\.htm
1. Default
2. Content Type
3. PerceivedType
- Double click each of the above keys
- check the value data (default value data)
Defaut = htmlfile
Content Type = text/html
PerceivedType = text
- If the value data is different, change it to the above default value
4) Reregister the following dll files
regsvr32 licwmi.dll
regsvr32 regwizc.dll
regsvr32 licdll.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 msxml.dll
regsvr32 shdocvw.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
5) Rename/replace the dll files
rename c:\windows\system32\licwmi.dll licwmi.old
rename c:\windows\system32\regwizc.dll regwizc.old
rename c:\windows\system32\licdll.dll licdll.old
rename c:\windows\system32\wpabaln.exe wpabaln.old
expand d:\i386\licwmi.dl_ c:\windows\system32\licwmi.dll
expand d:\i386\regwizc.dl_ c:\windows\system32\regwizc.dll
expand d:\i386\licdll.dl_ c:\windows\system32\licdll.dll
expand d:\i386\wpabaln.ex_ c:\windows\system32\wpabaln.exe
copy c:\windows\system32\licwmi.dll c:\windows\system32\dllcache
copy c:\windows\system32\regwizc.dll c:\windows\system32\dllcache
copy c:\windows\system32\licdll.dll c:\windows\system32\dllcache
copy c:\windows\system32\wpabaln.exe c:\windows\system32\dllcache
6) Initiate to activation tool
- Create a new dword value under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
NT\CurrentVersion\Winlogon
- dword value named : Activation Required
- set the dword value as : 1
(or)
- goto HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current
Version\WPAEvents\oobe timer
- change atleast one digit of oobe timer value data
7) Delete RESET5 keys
- start > search tool > search for reset5.* > delete all the files
8) Rename/replace WPA.DBL file
ren c:\windows\system32\WPA.dbl wpadbl.old
MGA Diag : http://go.microsoft.com/fwlink/?linkid=52012
Validation tool : http://www.microsoft.com/genuine/diag/
Regards
Apr 27, 2012 | Microsoft Windows Vista Home Premium with...
Tip
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
on Jan 24, 2010 | Computers & Internet
Pop-up message 'chrome.exe - Bad Image' in title bar, content reads : The application or DLL C:\Program Files\NewDotNet\newdotnet6_38.dll is not a valid Windows image. Please check this against...
Generally this error means you got the wrong version of the dll installed. IE you are running XP and installed one for Win98 and the one for XP is slightly different.
Sometimes this is a path issue and all you need to do is to copy (not move) the DLL and put it with the others in System32
In addition there are a few specific problems which cause this type of error
http://support.microsoft.com/kb/907300
Autocad also has a similar problem for which there is a patch.
So please be more specific.
Is this just one dll? If so what is it?
What application and what consequence?
You should also try reregistering the dll
using your example
go to start / run and type
regsvr32 xxxx.dll
hit enter and wait for it to say success
Nov 07, 2011 | Google Chrome
Mtp function problem
Samsung MTP function Problem Solution It really worked for me.
1.)first copy umdf.exe from "wmp11-windowsxp-x86-enu.exe" to your Desktop, two methods:
a)unpack wmp11-windowsxp-x86-enu.exe(ex:with TotalCommander->Alt+F9) and copy umdf.exe to your Desktop
b)run the wmp11-windowsxp-x86-enu.exe(if you run it will extract the %TEMP% folder)
Click Start -> Run -> %temp% [ENTER]
Press F3 and search for "umdf.exe"
Copy this file to your Desktop
Cancel the WMP11 Setup
2.)Rename the folowing files, just copy&paste into your Command Prompt:
rename C:\WINDOWS\system32\drivers\wudfrd.sys test_wudfrd.sys
rename C:\WINDOWS\system32\drivers\wudfpf.sys test_wudfpf.sys
rename C:\WINDOWS\system32\wudfhost.exe test_wudfhost.exe
rename C:\WINDOWS\system32\wudfsvc.dll test_wudfsvc.dll
rename C:\WINDOWS\system32\wudfx.dll test_wudfx.dll
rename C:\WINDOWS\system32\wudfplatform.dll test_wudfplatform.dll
rename C:\WINDOWS\system32\wudfcoinstaller.dll test_wudfcoinstaller.dll [ENTER]
3.) Now run the umdf.exe and re-install it. After it's finished connect your phone and your MTP problem is solved.
Oct 24, 2010 | Cell Phones
Sprtcmd.exe-bad image Application DLLC:\WINDOWS\system 32\NTMARTA.DLL not a valid image. Check this against your installation diskette
You may be able to perform a restore, From the start menu chose programs>accessories>systemtools>System Restore
Choose a restore point that you think has a best date and time when your pc was working better.
Apr 16, 2009 | Dell Dimension 8250 PC Desktop
Ddl error message... bad image
Hi there.
You might get this if the file mcenspc.dll is leftout while uninstalling some program or when attempted to elimitate spyware or malware through spyware scan.
This has proved not to be a threat and it is safe to remove from the Computer. To do this :
1. Click Start -> Run -> Type System32 -> Ok
2. Look for mcenspc.dll
3. Right Click on the file and click Delete
4. Reboot the computer
Everything should be fine now
Apr 11, 2009 | Computers & Internet
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Error ''DLL C:\WINDOWS\system32\jemobibe.dll is not a valid Window
you computer is virus and trojan horse affected, use latest antivirus. you can find the .dll file to this website..http://www.dll-files.com/dllindex/index-s.shtml
download the missing file
Jan 25, 2009 | Computers & Internet
My laptop wont let me use most programmes because of system 32
What specific error are you getting and what operating system do you have.
Jul 17, 2007 | LG X-Note LM50 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
