Question about Hayward SAND FILTER, PRO SERIES
I have a hayward vari-flow valve sp714 and I need the replacement number for this
    President:
  • Hayward Master
  • 1,378 Answers
It is still the same valve only the part number adds a zero...it is SP0714T. We sell it for $97.99 with free shipping to the continental US. We currently have several in stock.
John
Posted on May 19, 2011
How do I replace the spider gasket
What filter do you have?
Some of the newer filter valves, do not have a replaceable spider gasket, it is part of the rotor base plate, like on a Hayward SP714 T1 Style valve.
See Pic:
25522633-w440f4xqb2ju5vbxyy5bo3yg-1-0.jpg This type is on the rotor assembly vs. the style that has the gasket as part of the valve body, and that is removable and replaceable, see pic:
Mar 05, 2015 | Pool & Spa
I can't turn the sp714 valve, how do i fix this?
this is a very simple valve. if you cannot turn it, i suggest removal from the filter body. inspect the inside of the valve. there may be a toy or something caught in the cavities or if not winterized properly, might have cracked
Jun 09, 2014 | Hayward SAND FILTER, PRO SERIES
Replace sp714 key
There is a flat edge next to one of the bolt holes on the key ass\'y that matches a flat edge on the valve housing.
Sep 11, 2013 | Hayward SAND FILTER, PRO SERIES
Hayward vari-flow valve sp714 cloudy water
Otherwise chemistry fine?
whenever someone is vague about chemistry residual readings, but provide a pH reading, I'm always Leary.
  • bring pH up to 7.6
  • Balance Total Alkalinity at 120 ppm
  • Bring Hardness to at least 200 ppm
  • Keep Chlorine level at least 3.0 All the time
  • ISO Cyaniric acid / stabilizer at least 30, not exceeding 80 ppm
  • Use a Natural Clarifier weekly - rate = 1 ozs per 5000 gallons
  • Use Algaecide (not from Kmart!) weekly
  • Clean filter whenever pressure approaches 8# over starting
  • Filter for at least 1 turnover per day. This is usually 8 hours in most regions
Follow this, should be good
May 25, 2012 | Hayward SAND FILTER, PRO SERIES
Need help replacing hayward sp714 diverter seal assembly. not sure how to het the old one out
Any idea on how to install new one yet? I put 220lbs of my own pressure to set spring to get key back into handle with zero luck
May 12, 2011 | Hayward SAND FILTER, PRO SERIES
Low flow
The model number you give is for the multi port valve. Did you need the valve manual or the filter manual? Go to haywardnet.com for their full line and manuals. Here is the link for the SP0714 valve at their site. It is in PDF format...
Jul 16, 2010 | Hayward SAND FILTER, PRO SERIES
My cousin has the hayward sp714 filter. she lost the manuel for it. i need to bakwash and clean the filter. where can i find a owners guide for this product? the pool is to green and the pressure on the...
Instructions are on side of filter tank.Looks like a pro series top mount. Turn pump off.Press down valve handle and turn to backwash. Start pump. When water runs clear , rinse and return to filter. The pressure gauge is defective! Replace. Superchlorinate pool.
Aug 16, 2009 | Hayward SAND FILTER, PRO SERIES
Leaking from the backwash port in the filter position
it is not seated all the way try turnig to different positions several times if this does not work it probably sprocket wheel under handle assembly is bad or unseated make sure pump is off when changing positions
Jun 28, 2009 | Hayward SAND FILTER, PRO SERIES
Control Valve handle wont stay in position
The valve should be about $100. We sell it for 90 something. You can rebuild them with gaskets and the spring. There should be a model number on yours, care to post it? Something like SP711, SP714, etc.
www.arrowmotor.net
May 29, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
591 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
