Question about VOX AC15VR VR Series 15 Watt 1X12 Valve Reactor Combo Guitar Amp Bundle
Horrific intermittent noise at higher volumes when amp is warmed up. Something overheating? Amp tech says its's not worth fixing. Described something about a "reverter"? Think he meant Reverb - strong european accent...pointing at the digital reverb thingy while he spoke.
  • thebelfastch May 20, 2011
    Thanks, will do that. It was an electronics expert who looked at it - said it looked fine in all regards, but he didn't actua;;y plug it in to listen- -didn't charge me either so...
  • VOX Master
  • 5,603 Answers
Look for bad soldering around the volume control pot leads. I think you need a new amp tech that can troubleshoot a problem.
Posted on May 20, 2011
    Thanks, will have alook at those. It was an electronics expert who looked at it, though he didn't plug it in or anything, didn't charge me anything. Said it all looked good to him, but the Belton reverb module must be faulty. Wonder if its easy to replace?
  • Fred Yearian May 25, 2011
    The reverb is NOT likely to be a separate module. The digital reverbs are fairly reliablle, again any connectors and soldering are usual culprits. The A-D and D-A convertors sometimes fail and get noisy. Those are EASILY diagnosed with circuit cooler spray.
My Marshall AVT150H has low output.
How do the pots sound? any stactic on the volume pots ? may need replacing or cleaning them if so . I would also consider replacing the tube
Jan 29, 2013 | Music
I have an Ibanez TSA15H amp that keeps blowing the F6 fuse. the fuse is a 500mA, but Ibanez told me to change it to a 100mA fuse and that would solve the problem. i did this, and it still blows. also...
This appears to be a common problem with this amp. Putting a smaller fuse will only cause it to blow easier...not sure what Ibanez techs were thinking. Mine blows with 500mA fuse...usually because failing to let it warm up the 30 seconds with standby switch off. I have used .75A-250V fuse and it eliminates the problem. Note: it also defeats the purpose of the fuse and leaves the circuit unprotected....voids warranty/fire risk/ shock risk/world will end, etc. I don't recommend using higher rated fuses but it appears that portion of the circuit draws more than the 1/2 amp fuse can handle.
Jun 29, 2011 | Ibanez Tube Screamer Series TSA15H Head...
The attenuator does not seem to work like it is described. It does not go smoothly down in volume but makes a noise like pots on a guitar when they need to be cleaned. The low volume has a very narrow...
A tube amp may take minute or two to warm up the vacuum tubes. Use CRC226 into the volume controls thru the little slot where the leads go into the pots. The pot may have been worn out and require replacement.
Jun 20, 2011 | Thd Univalve 15w Class A Amplifier Head
Hello, I own a hotrod deluxe. I take great care for it and never move it. Normally on the clean channel, the volume is regulated by the volume and the master. Today the amp sounded only half as loud as...
Do you turn on standby every time and wait for the tubes to heat up first? If you don't, it can severely damage the tubes.
But a common cause of this could be just old tubes. Like any other piece of technology, tubes get old. If you like to play your amp LOUD then they wear out a lot quicker. You have to replace tubes every now and then. Because I'm not there to check out your amp, I can't give you an exact answer but it sounds like that's the problem. This isn't always a bad thing. You can make the sound of your amp exponentially better with nicer, new tubes. Your amp has 12AX7 tubes. Very common tubes to use actually. I'm not sure what kind of music you play, I'm assuming mostly rock and blues. But here is a list of tubes and reviews on them.
http://thetubestore.com/12ax7review.html
This is how to replace a tube:
http://www.ehow.com/video_4438285_change-pre_amp-tubes-guitar-amps.html
Upkeep on a tube amp:
http://www.ehow.com/video_4438295_replace-tubes-guitar-amp.html
A note he doesn't make in the video is to dust out your amp. I use the compressed dust spray for the inside of computers.
So overall, stop turning up your amp to 11, make sure it's well ventilated and dust it out from time to time. Hope this helped.
Jun 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I have a Behringer EPX 2000 amp. The limit lights are lit up and the amp isn't powering up properly. There is a bad burnt smell to the amp and sub so i'm pretty sure something has blown. The limiter switch...
The limiter probably delayed the eventual damage. Nothing prevents all damage absolutely.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech for forensics and further action.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 17, 2011 | Behringer EPX 2000 EUROPOWER
Its a marshal 8080 valvestate 80 v and it buzzes and some of the knobs crackle when turned,
Buzzing could be normal for this amp, especially if you have the gain cranked way up (or the volume way up) see if the buzz goes away when you turn the gain/volume down. If not, there is a problem that needs to be properly diagnosed by the amp tech at your local music store. The crackling is also unfortunately rather normal for an amp that's a little older. Oxidation builds up inside the knobs and makes that noise as you turn them. If it only happens when you change settings I wouldn't worry about it, but if it gets bad, a tech guy can clean it out for you.
Feb 20, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Volume Sporatically Fades Out
Take it back and have him try it with you there so he can hear what you're hearing. He should cover his work unless its something that went wrong after the repair.
Jul 23, 2009 | Music
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
VOX AC15VR VR Series 15 Watt 1X12 Valve Reactor Combo Guitar Amp Bundle Logo
145 people viewed this question
Top VOX Music Experts
rhodesworks
Tom Chichester
Are you a VOX Music Expert? Answer questions, earn points and help others
