Question about Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A/37 I have like most that have this tv , No power except a red light that flashes 7 times and pauses and then repeats . I have been told that it's the power supply or the fuses . I have checked a replaced the fuses but still have the same problem Ihave also replaced the power cord going to the power supply and still have the red light . Is it the power supply ?
  • 1 more comment
  • runmhard Sep 23, 2008
    can you help me locate the capacitors, also how much were they were, and maybe a part number, thanks in advance.
  • blistig Dec 08, 2008
    are the capacitor black and there big i found in my tv two of them and there bulged up
    where i can find them
  • Axle80
    Axle80 Jan 13, 2009
    RPD, Which board had the bad capacitors?
  • 52 Answers
A 7 bliink error for this model is an 8.6 volt error normally caused by the y main overloading the power supply. disconnect the y main from the power supply and if the tv starts up check primary voltages per power supply sticker on pdp and if correct replace y main and y upper and lower buffer boards as they work together as circuit
Posted on Aug 14, 2008
I had same problem. The tech came out, took off the back and immediately found the problem. 2 capacitors were "blown". You can tell because the top of the capacitor is bulged up, not flat. He said it's not uncommon because they are 10V capacitors. He replaced them with 16V capacitors and told me I should be good. TV is as good as new.
Posted on Sep 09, 2008
Flat screen tv problem
42PF7320A: 7 blinks is missing 8.6VDC from supply -- connector CN-1M46, pin 3 (out of 11 pins), goes from power supply to main/input board.
Apr 21, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Nov 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Tv turns off and I get a red flashing light on philips flat tv model 42PF7320A/37
After looking through the user manual I could not find any error codes to diagnose your problem. I suggest calling Phillips Customer Support at 1-888-PHILLIPS.
Sep 30, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
FLASHING POWER RED BUTTON 7 TIMES
I believe that is a bad power supply board. You can unplug set ,open the back access panel and look for swollen electrolytic capacitors they will most likely be slightly rounded on top instead of flat top like the others.Not sure if just replacing caps is enough we mainly swap out whole board.Some models' replacement power supply is slightly different from original in that a couple of the plugs are in different spots and require an extension cable.
the tv dude
Apr 01, 2009 | Sony KDS-R50XBR1 50" HDTV
Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Mar 08, 2009 | Philips Televison & Video
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
349 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
