Question about Weber Genesis Silver B Grill
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
    Brigadier General:
  • 4,736 Answers
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
Posted on May 19, 2011
Weber spirit won't get hotter than 300. What's wrong?
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jun 19, 2014 | Weber Genesis Silver C Grill
My weber genesis E 330 thermometer never goes higher than 400 degrees F Why?
Jun 04, 2014 | Weber Genesis Silver B Grill
I have a full tank of propane - grill will not ignite. I have a weber silver model
Hi, Check the igniter and also the gas nozzle that it is not plugged with grease. Clean up and try again. Make sure that igniter is working properly. Replace if nescessary.
Jul 09, 2011 | Weber Genesis Silver B Grill
I installed a new 7509 ignitor on my 13 year old weber genesis gas grill and the gas does not ignite when pushing the ignitor button. I installed the ignitor with the box opening on the bottom and checked...
If the spark you see is in the ignitor box and not at the burner(s), then there's a wire loose somewhere or the ignitor is not grounded properly. Also check to see if the ignitor tips in the grill next to burner(s) are covered with grease. If so, clean them with a cotton ball dipped in alcohol. Check each ignitor wire at each ignitor , make sure they are secure,
Feb 20, 2011 | Weber Genesis Silver B Grill
First two burners work fine but when I turn on third burner (back) it cuts out the whole grill on the Weber genesis
This is very common with faulty regulators. The regulator is located on the hose (it is a metal silver disc located at the end of the hose where the hose attaches to the propane tank.)
To replace the hose and regulator, you need to detach the hose from the grill. Your local grill store should have replacement hose and regulators.
Hope this helps.
-Ben
Tanks 2 You Propane
propanetanks2you.com
Jan 27, 2011 | Weber Genesis Silver B Grill
Ignition push switch will not create a spark
no spark? bad ground on igniter, igniter loose in its mounting, or to far away from metal may also be bad igniter.
May 21, 2010 | Weber Genesis Silver C Grill
The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly.
However you can try adjusting the spark gap to see if this will resolve the issue.
Heat will often expand the spark gap thus rendering a spark impossible.
Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery.
Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Oct 03, 2009 | Weber Genesis Silver C Grill
How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
May 21, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
2,126 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
