Need to find a power cable for the 2wire gateway 2701HG-B router
    Sergeant:
  • 308 Answers
Just take the old one to radio shack or walmart and find one that is similar. The power supplies that they include with that router are JUNK work about 6 months max.
Posted on May 19, 2011
Does the gateway 2701HG-b support WPA-PSK security the label says WEP I need WPA
Yes, the gateway 2701HG-b supports WPA-PSK. Refer to user's guide here:
http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf Pages 25 to 28 will clearly show you how to set up WPA-PSK. Hope this helps.
Mar 27, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
I have a 2701HG-B gateway furnished by AT&T DSL I want to change to wireless\r\nWill my gateway work with wireless? I will have to install wireless cards in my computers what do you recommend? My...
You need a wireless router for you to use Wireless connection
I recommend DLINK, Belkin or Linksys router any of those will work.
you can still use wired connection because router has 4 ports for wired connection but if you prefer to use wireless then you need to buy USB wireless network adapter.
Sep 06, 2010 | 2wire (2701HG-B) Wireless Router
How many pc's can a 2wire gateway 2701hg-b
generally 4 at a time, but I don't know if there's really a limit, but you'll be sharing your bandwidth, which will slow down your connections.
To find out, open the prompt window and type the following:
ipconfig /all (notice the space) - hit enter.
Find the Default Gateway IP address.
Open Internet Explorer, and type the IP address above into the browser field for going to web pages. You will now be able to check the router yourself.
The ip may be something like: 192.168.2.1 - check it out.
Feb 13, 2010 | 2wire 2700HG-B Router (2700HGB)
Im a new compaq presario cq60 owner- im trying to setup wireless network at home-att.is my only option in my area- have a 2wire 2701hg-b wireless router and cant get it to work internet,wireless only with...
You will need to check the wireless settings of the router.
You said that it works only with the ethernet connection but not with the wireless connection.
Check the IP address of the computer when it is connected with the cable to the router. note down the default gateway number.
Open the set up interface of your router with the Default gateway number.
once you are able to open the set up interface of your router, you will be able to change the wireless settings of the router.
after that you will need to conncet to the wireless network on your laptop.
Click Here for more Information
Oct 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless Internet stopped working. Can't reconnect.
If restarting the router and restarting computer did not work (unplug both power cables), then you need to log into the router and check network settings.
To log into router type the router IP on internet explore bar, then enter user id and password.
You find details on how to do this, IP and passwords listed on the owner manual.
If wireless security settings on router are fine, then you can reset router to factory default using the pinhole switch. You will need to enter all your broadband settings to have the router working afterward.
Apr 27, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2701HG-B constant power loss
Hard reset the router and reflash or update the firmware.
If still wont work then it will be hardware problem (bad memory).
Oct 03, 2008 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2701HG-B
gateway.2wire.net... try that, it should work
Dec 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
