Everything appears fine on our 14 month old HL-4070 CDW. However we're still unable to use it. The LCD continues to display "print unable 3B, even after 5 power on-off cycles. Suggestions? :o)
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
It could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate the solution. THANKS FORUSING FIXYA.
Posted on May 19, 2011
I recently made my canon iP2770 a continuous ink one. It as going well, untill it said "The holder is in the ink cartridge replacement position.Close the printer's cover.Ink has run out. View the
Throw it in the trash and buy a laser jet.
People who print a lot, and do I, would be better off buying a new printer every time I went to buy cartridges.
The printer I bought was a brother HL 3140 cdw.
~$200 at staples
The cartridges are expensive ~$200 and lasted me for a year.
I said a year!
Jan 27, 2018 | Canon PIXMA iP2200 InkJet Photo Printer
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
My brother HL 4070 CDW printer says to change the belt. What do I do?
Ther is a picture in the manual that will show you. It won't insert on here. Send me and email joediaz911@gmail.com, I will send yout the PDF.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2011 | Office Equipment & Supplies
We have a Brother HL 4070 CDW printer and it's leaving black smudges down every printed page. We have tried vacuming it out, but that did not help the smudges. Any ideas?
Hi there !
this is a commun problem for all the printers, you should clean you printer's inside !
for that printer you habe to check all the way where the paper moves.
Aug 20, 2010 | Brother Office Equipment & Supplies
I have the Brother HL-4070CDW and I have a TONER LIFE END message and it will not allow me to print anymore. How can I make my printer keep printing until I see visible quality issues?
With the front access door open, press and hold the cancel button. While still holding the down the cancel button, press and hold the reprint button... you should now see the toner reset menu. Why we can't get there from the machine info/reset menu to begin with, well, guess Brother wants to sell you more toner. ;^)
Dec 07, 2009 | Brother HL-4070CDW Printer
What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Oct 10, 2009 | Brother HL-4070CDW Printer
Will not make connection to wireless brother hl 4070 cdw printer
You might not be on the wireless network or the printer might not be on the wireless netowrk. try connecting to it via a usb cable and see if that works. if so try reconfiguring the settings on it for your wireless network than try again. Also if you have the disk the printer came with you can uninstall the printer put back in the disk, reinstall the printer and it might do all that I am saying automatically.
Sep 12, 2009 | Brother HL-4070CDW Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Reset page counter
Try to unplug your printer and leave it for 1 to 2 hours.
Feb 27, 2008 | Dell 1710n Laser Printer
74 people viewed this question
k24674
jasbo
jasbo
