Question about ASUS Eee 4G Notebook
Eee PC 2G power supply
The power supply cord is rated 110-240V. When using it on a 220 power supply the plug end of the cord popped and began smoking. No damage to the computer, but now I need a new power supply cord. Where can I purchase such a cord or can I snip off the plug end and attach a normal 110 plug so I can once again recharge my Eee PC?
  • Arnold Simon Aure
    Arnold Simon Aure Oct 12, 2013
    Already out of warranty. If the power supply of the printer was damaged, can I use different canon printer's power supply.thank so much.
  • ASUS Master
  • 7,733 Answers
220 is for dyers and air conditionners.If you lucky your pc cant run on it.110-240 is the same so dont miss with you can get electrocuted
Posted on May 01, 2012
    Sergeant:
  • 395 Answers
Why don't you contact the supplier and get a replacement. It must still be within its 1 year warranty period?
Posted on Aug 15, 2008
My computer did not start when i tryied to turn it on, so i pushed the red butten to the side at my power suply and tryied again ther was a loud bang from the powersuply and ther was smoke comming out from...
The only thing to do at this point is to replace the Power Supply with a KNOWN to be good, compatible unit, and see if the rest of the computer hardware components are okay.
Going by your information stated that the Power Supply is an Enhance ENP-2224B SMPS, (Switched-Mode Power Supply), it is a special shape.
If it wasn't for the Slim Micro-ATX computer case you have, you could use an easy to obtain ATX form factor Power Supply.
From a quick search though it looks like a replacement unit is affordable,
http://www.censuspc.com/Enhance-ENP-2224B-2G-240W-SATA-TFX12V-P4-Power-Supply-for-Slim-microATX-Desktop-Case-Serial-ATA-Ready-bulk-pack-SKU-ENP-2224B-2G-pr-3033.html
There is simply no way to tell if the motherboard, and/or Processor, and/or Ram Memory, and/or Harddrive, etc., is okay without having power.
Unless you transfer the components on the motherboard to another working motherboard.
[NOTE*
If your Power Supply has a rocker switch on the back that lets you use 120 volts, or 220 volts, make SURE it is set to the right voltage.
USA?
120 Volts
Europe?
220 Volts
Australia?
220 Volts
Japan?
100 Volts ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 26, 2011 | Enhance Technology ENP-2224B, Enhance 240W...
I will be in Asia where the power is 220. Will I need a transformer/converter to use my laptop? My digital camera says it will work on 110 or 220 and a tranformer will damage the camera. Is this the...
The power cord for your laptop is a transformer. However, is is in all likelihood, meant for use in the U.S. only and does not have a selector for 220v. You will need an power cord that is meant to work with 220v. I'm sure there is one available for your laptop. Just make sure that when you purchase it, that the output is rated the same as the one you use now and you will have no problems.
May 05, 2011 | Computers & Internet
I accidentally plug my aiwa excelia cd player model xc-003 to 220 volts instead of 100 volts. Iheard a small popping sound when i plug the unit to 220 volts.
If you're lucky you'll have just blown the internal fuse.
You need to remove the cover and look for the little glass fuse on the PCB where the power cord comes in. If it has blown then look at the metal cap on the end of the fuse and is should tell you what rating it is (2A etc). You should also check to see if any other components appear damaged before replacing the fuse.
May 03, 2011 | Aiwa Audio Players & Recorders
When I plugged my pc into the surge protector and turned it on, it began to start and then a loud pop, now it does not get any power. Can I replace the power supply to fix this problem.
Wow. Never heard this one before. If was like an electrical pop, then you could try using another power supply. But there is also a chance that your motherboard could be fried as well. I've never ran into that problem.
Jan 14, 2010 | Enermax EG301P-VB (eg301vb) Power Supply
I bought a MFC-7840W 120v to asia and plugged it into the local socket seems it popped and does not power on, was told it had an international power supply. Nothing was smoking or seemed burnt. Is there a...
An International Power Supply usually has a power selector switch on the back of the printer. Asia uses 240 VAC (At least I think it does).
Check the back of the printer and make sure that it is set properly and try again.
Be aware that if you plugged a 220/240 source into the printer and the printer is set for 110, then more than likely, you have fried the power supply.
Don
Nov 04, 2009 | Office Equipment & Supplies
My eee pc 4G surf won't turn on. It started having problems when the power cord was bumped - causing it to immediately shut down. Then it just stopped booting all together. I replaced the power cord and...
Most likely, either the power jack inside the machine (jack itself or solder joints) or the plug on the power cord was damaged; obviously the plug is only a few dollars to replace, the jack also only a few dollars, but much more labor intensive. My experience tells me it's probably the power jack. If you have any way to externally charge your battery and, using it, find the machine operational, that pins it down pretty well. When the external supply is used, the internal battery is supposed to be switched out of the load circuit and into charging mode.
Aug 06, 2009 | ASUS Eee 4G Notebook
Plugged my computer into a 220 outlet!
You burned the Power supply you don't need to switch motherboard out just knew power supply. And in the future there is a switch located on the back of them that will make them a 220v powersupply. But usually only a high end PC for gamers will need that so just put in a new powersupply and you should be good
May 03, 2009 | Logitech R-20 Computer Speakers
What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
ELECTRICAL REQUIREMENTS
ELECTRIC Dryer
CIRCUIT - Individual 30 amp. branch circuit fused with 30
amp. time delay fuses or circuit breakers.
Use separately fused circuits for washers and dryers, and DO
NOT operate a washer and a dryer on the same circuit.
POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
Hz, Alternating Current.
POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
conductor power supply cord NEMA 10-30 type SRDT rated at
240 volt AC minimum, 30 amp., with 3 open end spade lug
connectors with upturned ends or closed loop connectors and
marked for use with clothes dryers.
WARNING – Risk of Shock. Appliance grounded to neutral
conductor through a link. Grounding through the neutral link is
prohibited for (1) New branch circuit installations (2) mobile
homes; (3) recreational vehicles; and (4) areas where local codes
do not permit grounding through the neutral, (1) disconnect the
link from the neutral, (2) use grounding terminal or lead to
ground appliance in accordance with local codes and (3) connect
neutral terminal or lead to branch circuit neutral in usual manner
(if the appliance is to be connected by means of a cord kit, use
4-conductor cord for this purpose). USE COPPER CONDUCTOR
ONLY. The dryer MUST employ a 4-conductor power supply
cord NEMA 14-30 type SRDT or ST (as required) rated at 240
volt AC minimum, 30 amp., with 4 open end spade lug
The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
Asus Eee PC 2G series will not boot up
Try to unplug the battery, wait 10-15 seconds and plug it again. Sometimes it gets stucked with hardware issues and this is a kind of "reset". It doesn't affect your data.
Jan 07, 2009 | ASUS Eee PC 2G Surf Notebook
ASUS Eee 4G Notebook Logo
108 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
