Question about Blaupunkt Travelpilot RNS-150 CD Player
Have purchased a AUX to jack-plug interface to my Travelpilot E1, but it does not work. Seller tells me I have to turn on AUX-interface. How do I do so?
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
Intermittent audio via aux jack Kenwood KDC148, replace the E1 jack look else where?
you have a couple of options first of all it may not be the jack it maybe the cable that you plug into it also most decks have an auxiliary input RCA style on the back you can plugin RCA to 3.5 millimeter adapter and use that as an input instead of replacing the faceplate
Jul 14, 2014 | Kenwood Car Audio & Video
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Dec 28, 2013 | Jensen cd-472-bk am/fm cd boom box
I turned the aux function on on my alpine cdm 9821 unit. I purchased an audio adapter with a red and white plug (to plug in the back of the reciever) on one side and a regular 3.5mm headphone jack on the...
You must make sure where you plug in on the radio side is Aux input, most Radio Aux is at the front or come with special connector if it is at the back. Mostly radio back come with RCA is for Line out not Aux in.
Nov 28, 2013 | Car Audio & Video
Can't a wired head set to work on this TV!!
The head set won't work on the aux the aux is for an input such as a mp3 player or phone . The tv should have it's own jack it will say headphones or have a picture of headphones on it just plug the headphones into the jack plug and you should get sound
Jun 25, 2017 | Sylvania LC195SLX LCD TV
The plug works because the socket switch is turned on and the volume control button is green but when I plug in the auxiliary cable there's no sound? Is there something wrong with the inside of the...
Was the second aux cable you tried new or old? If both aux cables were older, you might possibly want to try (not necessarily buy) plugging in a new one. If you have done that: How old is this receiver? Brand new or older, if older it could be build-up inside the jack causing a break in the connection between jack and aux cable. If this is the case then a simple cleaning with a Q-tip and some alcohol could help immensely. If that's not the case, it sounds like you could have a short in the jack.
Jul 13, 2011 | Audio Players & Recorders
Does a pioneer deh-p550mp have an AUX. jack on the back or a set of AUX. RCA's to connect a device?
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio and scroll through the sources and make sure it is there.
5. buy cable and headphone to rca cable
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
Oct 06, 2009 | Pioneer DEH-P550MP CD Player
No sound when using the TV
1- Find the two audio out female RCA jacks on your tv. One is red one is white. Some older tvs may not have any, if so you are out of luck.
2- Purchase a stereo patch cord (male x male RCA) long enough to reach the LG's Subwoofer.
3- Connect the red and white plugs to the tv output and connect the red and white plugs to the "Aux In" female RCA jacks on the subwoofer.
4- Select stereo input for sound on the LG's user interface.
You will be able to upconvert the stereo input to various surrond modes by studying the control manual.
Nov 29, 2008 | LG LFD790 System
Aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Aug 13, 2008 | Kenwood KDC-MP435U CD Player
Blaupunkt Travelpilot RNS-150 CD Player Logo
171 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
