Question about Mr. Coffee 12-Cup Programmable Coffeemaker
How do you clean this product using vinegar? - Mr. Coffee 12-Cup Programmable Coffeemaker
  • 6,771 Answers
Put a small amount of vinegar in the coffee pot, fill with water "12 cups" add contents to main unit and turn on, when finished! empty pot in sink and refill coffee pot with water only and cycle it through three to four times to make sure the vinegar is flushed out of the lines, adding fresh water each cycle.
Posted on May 19, 2011
Testimonial: "THANK YOU FOR YOUR HELP..I THOUGHT THAT WAS THE ANSWER BUT WASN'T SURE."
How do I clean the Rainmate?
Twist of stem from bottom, if excessive calcium or mineral deposits you can soak in vinegar. Keep hole in stem clean. Do not use harsh chemicals on any rainbow products it will compromise the materials. Vinegar should work.
Feb 03, 2016 | Rainbow Rainmate Air Purifier
Tip
CLEANING A FIBERGLASS/PLASTIC SHOWER PAN
USE BAKING SODA AND VINEGAR DILUTED 1:1 WITH WATER. YOU MAY NEED A SCRUB BRUSH, BUT IT WILL DEFINITELY CLEAN THE PAN. SPRINKLE THE BAKING SODA GENEROUSLY AND THEN DOUSE WITH THE VINEGAR SOLUTION. WAIT FOR THE FIZZING TO STOP, THEN SCRUB RIGHT AWAY. LETTING IT SIT FOR AWHILE DOES NOT HELP. YOU MAY NEED TO RINSE AND REPEAT, BUT IT WILL WORK.
I HAD TRIED A MYRIAD OF OTHER PRODUCTS, INCLUDING LETTING BLEACH JUST SIT THERE FOR HOURS, BUT THIS TRULY SAVED ME FROM POSSIBLY PAINTING THE PAN OR REPLACING IT. DO NOT USE VINEGAR SOLUTIONS ON GROUT OR GRANITE. IT WILL ETCH THE GRANITE AND DISSOLVE THE GROUT.
on Aug 11, 2014 | Home
Suggest me the most common green cleaning products commonly found in every house. Are enough to do tough jobs?
Vinegar, Baking soda, Coke can be easily found in every house. And vinegar is strong in nature and can clean almost everything.
Cheers!
http://www.thoroughclean.ca/
Nov 27, 2013 | Windex Multi Task with Vinegar, 32 oz....
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    My parents gave me their old espresso machine, it looks gross when I take the top lid off. How do I ensure it is properly cleaned? It's the Krups allegro fnd 112
    You can buy coffee pot descaling products at the grocery or department stores, or you can use a vinegar and water solution to break down the mineral deposits. You can use a cloth to start the cleaning, but scrubbing with abrasives is not a good idea.
    If you use a retail product, follow instructions; if you use vinegar, use half water, half vinegar. Run it as though you were making expresso, using the frother while you do it. The frother can also be taken apart and soaked. Afterward, run the machine with clean water until all traces of the vinegar are gone. If it is really dirty, you may have to do it several times. Thanks for using fixya.
    May 08, 2010 | Krups Allegro FND112 Espresso Machine
    Steam not released through spout but trapped
    is the spout clogged? Try running vinegar through it, CLR is a good product, but may stay the plastic, if not eat it, so I recommend vinegar to clean the deposits that plug things up, it may smell a bit, but usually works. Once cleaned, use distilled water to keep it from happening again, or just clean regularly with vinegar.
    Feb 28, 2010 | Bionaire BU4000-UC Humidifier
    My toastmaster iron has a steam button and a spray button. They will not work. Should I clean the iron out with vinegar?
    You can try to remove the spray nozzle if it unscrews and soak it in vinegar or CLR (Calcium,Lime,Rust available at stores) solution. Yes or use vinegar water mix 1/4 c vinegar 2 c water, or again there are products that are made for iron cleanout but vinegar is the least chemical based and cheaper. Fill the sprayer with the solution, and the steamer also. Operate the iron on the highest steam setting and iron on a folded towel to clean it out. You may have to scrape out the scale build up from the sprayer if it wont clear with the solution.
    Feb 20, 2010 | Toastmaster Irons
    Is there a product on the market that I can use to clean the inside of my Maytag dishwasher? We have very had water and there seems to be a hard crusty film build up inside. The dishes are not as clean aas...
    Hello
    I have used Vinegar myself.
    just placed a large cup full in the top rack and ran it through with no dishes in the dish washer.
    and once the dishwasher was clean we used a small amount of vinegar to clean the stainless steel bowls and silverware and glass.
    I have also used this product:
    http://www.reliableparts.com/product/Glisten-Dishwasher-Cleaner-1476390/Dishwasher-Accessories-461418
    and it also worked..... although there are restrictions ( no stainless steel dishwasher tubs ).
    I found this site for you:
    http://www.mrscleanusa.com/tips/clean-dishwasher.html
    I found this product for you as a bonus although I have no personal experience with it
    http://www.smallwonder.info/?gclid=COyUycvLgaACFQwNDQodKm_Zjw
    Feb 20, 2010 | Maytag Dishwashers
    Shark steam blaster jr. makes steam but has no pressure
    yes no vinegar please. Try a product called scale clean or tablets for de-scaling coffee machines. Available from coffee machine retailers
    Sep 19, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
    Miele descaling funnel?
    DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
    To clean hard water deposits from a coffee maker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinegar until it comes out clear. Do this once a week and your maker will work much better. **************
    Use citric acid or LEMON JUICE CONCENTRATE instead of vinegar. It cleans just as well but doesn't leave the funky odor that vinegar does. You can run enough water to get rid of the vinegar taste, but the odor will linger for days or weeks. Much better to use lemon juice concentrate (no pulp!!) or one of the commercial products like the one available from Starbucks.
    Sep 15, 2009 | Miele Coffee System
    Mr. Coffee 12-Cup Programmable Coffeemaker Logo
    476 people viewed this question
    Top Mr. Coffee Coffee Makers & Espresso Machines Experts
    jmt
    Level 1 Expert
    Craig Butler
    Craig Butler
    Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
