Question about Kenmore Dryers
My kenmore 70 series gas dryer does not heat up everything else works but the heat
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
99% of the time. its your the coils. You can also test them with continuity tester, The coil is usually in a front door of your dryer, you may have to take the cabinet apart. They are very easy to replacemy kenmore 70 series gas - lanijo58.jpg
Posted on May 19, 2011
Just purchased a kenmore 70 series gas dryer turns on but wont heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Kenmore 73952 Gas Dryer
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
166 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
