Laundry washer says OE - Washing Machines
  • porsche917 Dec 14, 2008
    OE error code and will not drain
  • mpeezy74 Jan 12, 2009
    I have the same problem,water will not drain,someone told me its the pump,whats next?
    Sergeant:
  • 222 Answers
It sounds like your water inlet valve is stuck open. You have two on this machine, a hot water and a cold water assembly. You should be able to tell which was stuck from the temperature of the water spilling out.
It is an easy fix. To replace it you take off the top by removing the screws at the rear and pulling back on the top. Unhook the hose to the drain pump and drain the water out of your machine. The door lock on this model is likely set so that you cannot open the door if water is in the machine (they don't want you to flood yourself, but its a little too late for you) You can now access and remove and replace the faulty valve.
Put things back together, but leave the top off and see if the machine will start up and the door will open. If your door is still locked you should be able to reach down and find a pull tab around the door lock assembly. Pull gently on this and it should release the door.
After up get it back together and drained of water hopefully the error message will clear itself and you will be back in business.
Posted on Jan 05, 2010
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
We were doing a load of laundry and a symbol saying 0E came up. What does this mean?
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system.
Thank You
Sep 05, 2010 | LG WM-2277HW Front Load Washer
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
Oe message doesn't spin
This LG technicians service manual will help you access the drain pump for service and possibly the door switch for repair.
http://136.166.4.200/contents/Laundry/WM1815/WM1815_Service_Manual.pdf
Jul 17, 2010 | LG WM0642H Front Load
LG TROMM wm2075cw gives an error of OE... and won't spin out the laundry.
Washer has a filter, at the bottom left handside of washer, which needs to be cleaned out. Refer to manual. Worked for me :)
Nov 27, 2009 | LG Washing Machines
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Oe flashing does not spin
It's the pump motor - I pluged it into the machine and ran a test cycle (service manual link below) and there was the grinding noise. NOTE - I also tested the spin through the QC test mode (see pg 15 of manual) and that worked fine. BTW I pulled the pump out from under the washer instead of taking the whole thing apart much, much easier.
http://136.166.4.200/contents/Laundry/WM1832/WM1832xx_Service_Manual.pdf
Jan 14, 2009 | Washing Machines
How do i remove panel from front load washer
You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode.
Nov 25, 2007 | LG WM-2277HW Front Load Washer
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
524 people viewed this question
Top Washing Machines Experts
