SOURCE: maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
SOURCE: whirlpool front loader door locked
My Tech sheet reads F01 is a EEprom Error ? Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. ? Replace CCU board. Good luck and let mre know what you come up with
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
SOURCE: Error Code F01
Hi there, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
