Question about Canon PIXMA MP495 InkJet Printer
Since replacing the black ink cartridge, all copying (whether from printer or scanner) is multi-coloured when I keep pushing the "BLACK" button. I have removed both cartridged several times, replacing them carefully; I have scrolled all possible options in the hope of fixing this problem myself, to no avail... PLEASE HELP ?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
It could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate the solution. THANKS FORUSING FIXYA.
Posted on May 19, 2011
I have an Epson XP-202 printer which I use solely as a black and white copier. Accidentally I pressed the colour button for a copy which ( as the original colour cartridges are still in the machine) has...
Not sure about Epson but I had the same problem and the store where I buy my ink said that a lot of the printer companies require all the color cartridges with ink in them to work. My color use to disappear even if I just pushed black and they said that was the way they were made . They sell printers quite cheap but make their money on the ink. I got rid of mine and purchased a black only ink jet and it hardly uses any ink at all. Its a powder. You can copy many copies on eighty dollars worth of ink where the cartridges I went through several hundred dollars a year.
Jun 14, 2017 | Epson Office Equipment & Supplies
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error - says can't recognize an ink cartridge
Hi there
You can try this but it lots to do but may help
This message may be resolved by resetting the unit. Please follow these
steps:
1. With the printer powered on, open the cover. The ink will move to
the left hand side.
2. Push down on the end of the black cartridge. A clicking noise will
be heard.
3. Slide the cartridge out of the holder towards you.
4. Push down on the end of the colour cartridge. A clicking noise will
be heard.
5. Slide the cartridge out of the holder towards you.
6. Once both cartridges are removed, unplug the power to the printer
(without turning it off).
7. Reconnect the power cord.
8. Turn on the printer.
9. Open the cover. The carriage that holds the ink will move to the
left hand side.
10. Make sure the orange cap is off of the bottom of the black
cartridge.
11. Place the black cartridge in the bottom of the printer.
12. Slide the black cartridge back until is cannot go back any further.
13. Push up on the end of the black cartridge, a clicking noise should
be heard.
14. Make sure the orange cap is off of the bottom of the colour
cartridge.
15. Place the colour cartridge in the bottom of the printer.
16 Slide the colour cartridge back until is cannot go back any further.
17. Push up on the end of the colour cartridge, a clicking noise should
be heard.
Please note that the colour cartridge will stick out further than the
black cartridge.
Close the cover. The printer should make some noise for a few moments,
and then return to standby.
If the message persists, to clear the low ink-warning message, press and
hold down the button for at five seconds, and then release
it. This will disable the ink detection until that cartridge has been
replaced.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
HP Photosmart, black ink running out too soon.
Not many. Black is also used to make color prints. HP's business relies on selling you ink cartridges, not selling printers.
Dec 27, 2008 | HP Officejet 5510 All-In-One Thermal...
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA MP495 InkJet Printer Logo
447 people viewed this question
old marine
old marine
