Question about Carrier 38BRC060 Air Conditioner
Condensation pan has several holes, where can I go and buy one since Idon't think it can be fixed.
    Genius:
  • Carrier Master
  • 1,033 Answers
Hello, any heating and cooling store wil have condensate pans in stock, just make sure you have the proper measurements of the pan.
Posted on May 19, 2011
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
Coil is leaking. need to clean it out but don't know how? it's supposed to be easy. can you tell me what to do?
If the cooling coils are leaking, you'll need to do more than just clean it, You need to replace them, as you're loosing refrigerant gas. Or is it simply a case that they are sweating? If that's the case, the condensation should drip into the condensation pan and drain outside via the drain hole in the rear of the condensation/drip pan.
Cleaning the coils is a good idea. But, it will involve sliding the inner mechanical portion of the unit out of the outer shell of the cabinet. If you decide to do this, have a helper handy for it's removal.
Hope this has helped you and thanks for choosing FixYa.
Jul 25, 2011 | Haier Mechanical Air Conditioner HWF05XC7
The water drainage hole on my fridigaire ac is only 2 inches from the front of the unit, thereby sitting on the sill itself and pouring water onto my sill and down the inside of the wall. Is this a...
Sounds like a defect to me or a hole has rusted through the condensation pan.Generally, all drain holes are at the rear of the pan. That's why the rear of the unit is supposed to tiled down 1/4" to 1/2". That way, the water flows to the rear of the pan.
I hope this helped you and thanks for choosing FixYa.
Jul 22, 2011 | Frigidaire FAA060P7A Air Conditioner
I have a window air conditioner that is leaking water on the inside. we've have 90+ temps now for 5 days straight.
The problem you're having is usually a result of the condensation pan under the unit has a clogged drain hole. In addition, if the outer exterior of the unit is not tilted down 1/4' to 1/2", water backs up in the condensation pan and can not flow toward the drain hole.
Clearing the drain hole and being sure the unit is tilted enough, should solve the problem.
Jul 20, 2011 | Whirlpool ACQ128 Air Conditioner
My a/c unit is spitting out water, why?
If it's a window or thru the wall unit. The drain hole in the drain pan under the unit, on the outside may be clogged. Also, if the unit is not tilted down 1/4" to 1/2" on the outside, it will not drain as it should. Look carefully for the condensation pan's drain hole, as it may be hard to find, due to the clog.
Jul 15, 2011 | Heating & Cooling
Water drips out of the bottom of my wall unit after being switched off
Huge, usually that's caused by 2 things: The rear of the outside part of the unit is not tilted down at least 1/4' and/or the drain hole in the condensation pan under the unit is clogged. The drain hole is normally toward the rear of the drain pan, so water won't run down the side of the house.
Hope this helped you.
Jun 27, 2011 | Heating & Cooling
I do not know if this is a problem or not, but I hear water bubbling in the air conditioner when it turns on and off. It is more pronounced when it turns off. When I say bubbling, I don't think it is...
That's normal. It's the condensation that the unit collected dripping into the drain pan. Just make sure that the drain hole in the drip pan is not clogged. And if it's a window unit, that the outside part of the unit is tilted down 1/4".
Jun 24, 2011 | Friedrich WS10C10 Air Conditioner
Have a magic chef refridgerator and the water is leaking on the items below. Fan is working fine in the freezer compartment. There is icicles on the divider board. Checked the hole where the water...
at the back of the fridge there is a water drain hole. this will be blocked. you will have to unblock by pushing a thin wire etc down it, then pour a little warm water down to confirm it has been unblocked. if otherwise
There are two issues that may cause leaks near the door of your fridge. The fridge door may not close in full or the rubber gasket which encompasses the door frame may be clogged or torn, thus causing condensation and leaks. To repair this problem, you need to discover the faulty component. If the gasket is dirty, clean it by rinsing with a sponge. Check if an item in the refrigerator is preventing the door from closing properly. If the gasket is somehow impaired, replace it. When buying a new gasket, it is best to buy one that matches your fridge model or type of door. The more general the gasket, the harder it is to install it.
If the leak caused by the gasket, you may have to check the door and ensure that it closes tightly. If it does not close well, you may use the door screws and bolts to fix the problem. Another remedy is to put the refrigerator at a slight angle. Some fridges have adjustable legs, but if your model does not have such, you may want to buy some wooden shims or sheets of plywood and put them beneath the fridge.
Fridge Leaks due to the Drain Pan
The drain pan functions to catch water from condensation so that it does not leak over the floor of your kitchen. If the drain pan is somehow damaged, it may be the reason why you have a puddle of water around the fridge. The pan is located underneath the fridge. Pull it off, drain the condensed water from it, and check if there are any punctures into it. If there are some, you should buy a new pan or somehow repair the current one. One possible way to check your drain pan is to fill it with tap water once you have cleaned it.
Hope this helpout.......
Jul 28, 2010 | Refrigerators
Maytag Plus MTB2456AEW leaks from inside refrigerator onto the floor.
condensation- bad door seals. replace seals.
in fridge- condensate drain plugged. unplug drain under coils.
under fridge- condensate pan full. empty pan.
Aug 27, 2009 | Refrigerators
Water comming out of the bottm of the freezer door i think the hole to the evaportor pan is frozen can i use a hair dyer to melt it an were is the evaportor pan
This is a very common problem and has several reasons that may cause the problem. I have a lot of information that covers the different ways that this takes place and how to to resolve the problem all on one page. So read the complete page and choose the part that most fits your refrigerators condensate overflow. Thanks, Sea Breeze
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 16, 2009 | Kenmore Refrigerators
Carrier 38BRC060 Air Conditioner Logo
55 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
