Question about Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120
Hi, Mother board does not beep when starting. All hardware disconnected, (impossible to reach acer bios screen previously). Battery removed and replaced. Pb remains the same. Is there any solution before saying MB dead ? Thanks for answer
    President:
  • 2,992 Answers
You don't say you tried another power supply, and I'd suggest that. Then pronounce the motherboard dead and replace it if you still have the same trouble.
Posted on May 19, 2011
Acer aspire m3710 one long beeping
Must be a few years old? Sounds like the on-board battery. Remove the side and locate it, change it and the machine should start. It's usually a 2032 battery.
Once changed, you may have to go into BIOS and reset the time. Usually when the computer starts from the very beginning press delete and this should bring up the BIOS screen, then change the date and time, save settings and it should boot up with no problems. A friend had exactly the same problem with a different machine.
Jun 29, 2014 | Acer Aspire M3710
Need bios password?
Thats why they tell you not to save the information on a file on your hard drive. You should have it written down. I bet you won't make that mistake again!
May 29, 2014 | Acer AZ5771-UR21P 23-Inch All-in-One...
How to remove acer laptop bios password
You'll need to open the laptop and reset the CMOS battery.
I'd recommend doing a search for you make and model for additional details. But in brief:
1. Disconnect power adapter and remove the battery.
2. remove the screws around the hard drive compartment (bottom of laptop) and slide off the cover
3. remove the screws holding hard drive in place and slide out the hard drive
4. Disconnect or remove the small power lead that connects the battery to the mother board.
5. Reconnect and place everything back together.
Jan 11, 2013 | Acer Computers & Internet
Hi I have an acer aspire 7551-2575 with a black screen problem .How do I flash the bios?
Since the black screen happens when you turn on the laptop, take a VGA or other input cable that your laptop has a port for and connect to an external monitor that way. If done correctly and the monitor also doesn't display anything, this could mean a problem with the graphics chipset or other hardware. If the problem actually is the bios, then the laptop is bricked, and you should send it in on a warranty if you have one or buy a new laptop.
Oct 17, 2017 | Computers & Internet
Where is the battery for the clock and calendar located?
Its called CMOS battery installed in the mother board .
Feb 20, 2011 | Acer Aspire 3680 Laptop
Remove bios password for Acer Extensa 7220-101G08Mi
if you know the bios pass word go into bios hitting del upon start up then on pass word enter the old pass word then make the new one empty click save if you dont know the pass word then the back up battery on the mother board will need to be removed for several hrs
please rank this advice below
Jan 18, 2011 | Computers & Internet
Bios password
The only way to solve your BIOS password is to open the laptop and remove its button cell meant to run the clock and BIOS. You will have to reach the mother board and do it. Remove it for a minute or so and then connect up everythig as it was. And remember not to gove any passwords any where in future.
Aug 21, 2009 | Computers & Internet
Turn on the computer and you get a long beep followed by two short beeps a pause the repeats. The mother board is a Asus A84-SLI Delux
HI there..
1 long beep followed by two short beeps..
this Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information..
cause could be anything...
here are few - connections not connected or connected properly recent electrical storm caused a surge that damaged computer other hardware issues.. failing hardware device
solution (please note this is a labourious process)
first thing we need to isolate the problem.
remove any hard ware which is recently attached. remove external harddrives ....
open the cabinet.. reseat all the cables.. if it still gives you the same result then i am afraid could be a hardware problem...
Aug 20, 2009 | Office Equipment & Supplies
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Acer t180 bios set up
hmm you might need to flash the bios or reset the bios follow these instructions.
TO RESET BIOS
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
THATS IT BIOS RESET
Jan 10, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120  Logo
211 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
