Question about Garden
I have a homelite grass trimmer. Two short rubber hoses enter/depart from the plastic gas tank. One of the hoses is cracked, creating a fuel leak. The other is probably close to being the same. Where can I find replacement hoses and is it a project I can do myself. If not, can you suggest a homelite repair facility close to Sheboygan, Wisconsin. Thank you. Roger
    Problem Solver:
  • 10 Answers
Rubber hoses should be available from AutoZone or NAPA or any other reputable vehicle parts dealer, or online. Check the size of the hoses before you shop, to make sure you're getting the right diameter. Replacement would probably require draining the fuel from the tank and depending on the exact layout, you might have to take out a couple of bolts to find both ends of the hoses. Make sure the hose clamps or fixtures on both ends are tight and not in need of replacement as well. Unless it's a complicated internal layout, I see no reason replacement would require a shop!
Tools you'll need: Sharp scissors or knife to cut rubber to length, rubber hoses, gloves, wrench or screwdriver?
Posted on May 19, 2011
I have a craftsman quantum. Weed trimmer and won't prime gas to the carb, what do I look for?
fuel in the tank, cracked hoses to the primer , primer bulb cracked, primer valves affected by rubbish, grass or failed
May 22, 2016 | Craftsman Garden
Gas comes out of top of gas tank at fuel lines
with trimmers and small motors , this problem indicates an old plastic tank that may be cracking at the hoses
it also indicates that the plastic fuel line is shrunk at the point of entry ,is hard and so leaks
the fix is silicon hose ( expensive ) but is not affected by the fuel
pull the old hoses out of the tank and fit the new hose in
it will be tight to start but with perseverance you will get it in
other than that take it to a small engine shop and have them do it.
Jun 19, 2015 | Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
Gas is leaking, I think its the little plastic gasline thats cracked thats attached to the the gas tank itself, if so, where can I find a new replacement gasline to repair it?
All small engine repair shops carry the lines you need and you may even be able to pick up a fuel line "kit" complete with fuel filter and fuel lines at your Home Depot. They carry many parts and accesories for Ryobi and Homelite trimmers.
May 15, 2011 | Homelite Garden
Replace fuel lines,craftsman weedwacker, 358.798520 . Fuel lines disintegrated in gas tank. Three parts left in tank, fuel filter and two small plastic hose connecting items.How are these parts related to...
Fuel filter in tank with line going directly to the fuel pump side of the carburetor This is the end of the carb with a solid cover. . This line should have length in it inside the tank where it can flop around and stay on the bottom to collect fuel. The other line in the tank should have one of the little connectors on it and can be right up to where the hole in the tank is to hold it there.. This line should connect to purge/primer bulb on the longer outlet nipple. Another fuel line should run from the metering chamber side of the carb (the end with the hole in the cover) to the purge/primer bulb with the shorter outlet nipple.
The purge bulb "pulls" fresh fuel out of the tank via a vacuum created after depressing the bulb and the fresh fuel flows completely thru the carb and any air or old fuel ahead of it are drawn to the purge bulb which then "pushes" this mixture back to the fuel tank.
Jul 05, 2010 | Craftsman 25cc Gas Line Trimmer
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Cracked fuel line
you can get many sizes of hose at the home depot
May 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Fuel Lines leak where they pass through opening into tank
i had the same problem with my trimmer. you could replace the fuel line but if you don't want to hassle with fishing it thru the hole i suggest going to homelite.com and ordering the gas tank. it only cost me $18 with shipping and came with everything (tank, lines-with fuel filter, and gas cap). all you need to do is take out the 4 bolts on back of trimmer and the 2 top bolts holding the housing together. be careful not to nick any gaskets especially the one behind the 4 bolts. this is the crankcase gasket. also don't get anything in the crankcase that will score it as this will ruin the trimmer. also there are 3 spacer gaskets that go in the holes in the fuel tank and i believe a plastic heat shield between the gas tank and the bottom of the trimmer. you will see this when you take the tank off. just be careful and be sure all the bolts get tightend up (especially the 4 on the back as this is the back side of the crankcase). it only took me 15 min to replace it and the trimmer runs great. all the above info is if you have a trimmer with the gas tank on bottom. if the tank and gas cap are on top hopefully someone else will be able to help.
good luck
Jun 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
