Question about Dell L375P00 (KH624) 375Watt Power Supply
I CONACT THE POWER SUPPLAY AND HE WAS IN 110 V BAT THE VOLT IN MY HOUSE IS 220V WAHT CAN I DO
  • 367 Answers
Most, if not all power supplies have a little switch at the back near where you plug the power cord into. It will say 110V right now, you can slide it to the 220v position. If you have already plugged the unit to the wall and tried to power up when it was in the 110v position it may be damaged, in which case you may need to buy a new one.
Regards, Chris
Posted on May 19, 2011
  • Dell Master
  • 3,289 Answers
If you had the voltage selector switch set to 110 and connected it to 220 volts, there's little to be done besides removing it and replacing it.
These devices are sensitive and will not tolerate 220 volts when set for 110 volts for even the shortest amount of time. You will likely be wasting your time / money if you attempt to fix it as several components could be damaged but only one may have visible damage. The others will have been "weakened" or compromised and probably not last as long as originally designed.
I have found a refurbished Dell L375P00 375Watt Power Supply available for under $67, and others still for more and less and new and used on eBay. These may be your best options for getting up and running again.
I plugged my 32hlc56 into 240 outlet in Cebu and its only 120, no power now, can I have it repaired and where?
You should take your TV to some good electronic service and they should check if it can be repaired. Obvously you overcharged it and PROBABLY some part of the circuit board burned out. Maybe it's just a cable, or the insulation or maybe it has a massive damage. it's a question of verifying if damaged part can be replaced or repaired and for how much.
No way to tell for sure extente of damage, I'm just guessing.
If you are interested to read some "experience" with this incident, do a google search for
PLUG 110V DEVICE IN 220V OUTLET
why 220v power supply may damage system working on 110
My son plugged 110 volt stereo into 220 volt outlet can this be fixed or... - ok, this guy says was "his son", so blame the kid, haha
Read this for Yahoo answers:
https://answers.yahoo.com/question/index?qid=20111130034708AAEFYqG
Sep 04, 2015 | Toshiba 32HLC56 32 in. HD-Ready LCD...
I have a 440v 50 amp and a 220v 30amp main breaker box outside my house. the 440 goez to the inside of the house and i have to unplug the 440 and plug in myown 440 plug i connected to another breaker box...
Some of these numbers don't make sense?
I have Never heard of 440v and 220v in a residential application, they are two different systems, 480 volt is typically 3 phase power, and 240v is typically single phase, more in likely you have a 200- 400 amp main service, and a 100- 200 amp secondary service for the welder, that can't be 110 @ 200 amps?
I would need more info, and pictures of actual nameplates of the equipment,
and then I could advise a safe NEC electrical code answer...
Mar 17, 2015 | Electrical Supplies
I accidentally plugged computer avr 220v to 110 could it affect my power supply
If the computer power supply is a 240 volt unit and you plugged into 110 volt mains the the computer should be OK.
Some power supplies have a voltage selection switch on the back of the power supply switch to 110 volts and it should work.
If the power supply is 110 volts and you plug it into a 240 volts mains then you will damage the power supply and possibly the computer as well.
Mar 14, 2012 | HP Pavilion a465w-b PC Desktop
Washing machine w/ 110v plug in to 220v
DON'T!
Never plug a 110 volt anything into a 220 volt supply and never plug a 220 volt anything into a 110 volt supply. They are just not designed to do so. Their electronic's power supply and their motors are specifically for the specific voltages. Changing the plug at the end does absolutely nothing.
I just hope I have got to you in time!!!
John C
retired Englishman in SW France
Feb 19, 2011 | LG Washing Machines
Moved to new apt. Set up the windchaser pacr10 portable to outlet then press start the unit made a pot noise. It stop working after that. I then discover that the outlet wasn't a 110v it was a 220v. The...
Not much my friend.
Are you in the USA or other place where 110/120 volt is the norm???
How in the world did a 110 V - 15 or 20 amp outet get put on a 220 volt circuit?????
Is this a rental property? If yes, I'd be calling the land lord and if I didnt get any satisfaction there, I'd be calling the city or the county or who ever oversees rentals and I'd be calling the news paper!
If this is your house - get yourself a volt/ohm meter and check all outlets in your house and garage and outside ... If you are not sure how to do this, it would be worth the investment to have a electrician inspect this house.
I'm sorry our machine if finished and I am very glad you are not hurt.
Thanks for your interest in FixYa.com
please vote
thanks
a
Dec 11, 2009 | Windchaser PACR10 Portable Air Conditioner
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
My Generator is putting out voltage on both the neutral side and positive side of 110 Volt recepticles. When hooking a meter to both sides (Neutral & Positive) it is showing 184 volts! It burnt up a...
Check the voltage with a meter in all the recepticles with your meter leads in the left and right slots on the plugs. Is that 184 volts AC there? If so, your gen has big problems with the voltage regulator. Let me know what you read. You can check the right slot of each plug to the round ground hole on the plug too, should be 120 volts there.
Jul 01, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Dual voltage
contact emachines and ask them, not all power supply units have volt switches, the best thing you could do is have a physical look at the same model if you can find it in a store or view the specs on line
Nov 14, 2008 | E-Machines Computers & Internet
Dell L375P00 (KH624) 375Watt Power Supply Logo
96 people viewed this question
Alun Cox
