Question about Clarke Vacuums
Hello. I have just bought a 2nd hand CLARKE WOODMASTER CSS400B, but after using it for 2 minutes the blade has fallen out. Also on my table is a screw. How do I put it back together again?
2 Suggested Answers
  • 42927 Answers
SOURCE: I have just bought a beldray 5 in 1 steam cleaner
Beldray might be able to supply a replacement part.
Posted on Jan 12, 2014
Delta 36-600 table saw new belt run's and sounds great, BUT wont cut butter?? Any help would be great thanks. Oh could it be brushes?? Cheers Matt Blade is in the right way,Delta 36600 have brushes.
Not to insult your intelligence, check the blade direction. Looking at the tablesaw from the left side, the blade should be turning clockwise and the teeth cutting downward. Also the teeth should be very sharp. Typically a belt run tablesaw doesn't use brushes but a capacitor to start rotation. You didn't mention if the blade turns when started. Since you mentioned it sounds good when started I'd rule out the motor. Some saw blades have an arrow to indicate direction. Hope this helps. Good luck.
Oct 28, 2017 | Vacuums
It will not hold a charge. Been plugin for days at a time then it will run a minute then stop
Hello Karen, It sounds as though may have a bad battery or the charger is shutting down before the battery gets fully charged.
Nov 01, 2015 | Black & Decker CHV1210 Vacuum
My DC31 just stopped working while I was vacuuming my wood floor. Is only 2 mths. old. I bought this for the versatility so I don't have to lug my big Dyson up and down my stairs. The battery was
Don't overlook the obvious. My DC31 just stopped working when I was using it. No lights, no noise, nothing. After poking around for a a couple of minutes, I removed the battery and then re-inserted it. I gave it a good tap with the palm of my hand to make sure it was seated properly. Everything worked after that.
Jun 02, 2012 | Dyson DC31 Animal Bagless Handheld...
Can not remove blades i open door push up on tabs the blades will not move. i just bought it 2 weeks ago
I dont know that a vacuum has blades, but I would try and return it, before I cut up my carpet.
Mar 15, 2011 | Vacuums
I recently bought this machine 2nd hand but the power cord is missing. Can I get one from a dealer or whomever?
Contact any vacuum ckleaner repair shop in your area and they can supply a replacement cord. Check the local phone book under vacuum cleaner parts retailers.
Mar 04, 2011 | Vacuums
Do alto clarke have a supplier in Australia for vacuum cleaner parts? D T V 7 Thankyou
HI there Vacuum Guru here from VacuumSpot.com.au. Most alto clarke share the same parts as a Nilfisk Alto. We are an agent for these machines. If you use the email link on our site and let us know which model you have we should be able to get you any parts you need.
Oct 14, 2010 | Alto 302000405 Attix 8 Canister Wet/Dry...
How do l change the filters please
Hi there SmartAlec from NelsonVacuums.com.au assuming your dyson is the one pictured it will have 2 filters.
1st. If you look at the machine from the front there will be a filter cover on the left hand side. It is in a vertical position and is released by a smallish lever just above the cover.
2nd. The post motor filter is found under the clear bin. Simply take the entire cyclone canister off and you will see it sits on a filter cover. With a small flat blade screwdriver gently pry the cover off and access the filter.
NelsonVacuums.com.au carry all the filters for Dyson Vacuum cleaners in stock.
HAPPY VACUUMING! :)
Aug 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Table saw not turning on
yes that is a thermal fuse. wait a couple of minutes and reset it. If the blade is dull, replace it.
May 02, 2009 | Vacuums
Vacuums Logo
23 people viewed this question
Top Clarke Vacuums Experts
Are you a Clarke Vacuum Expert? Answer questions, earn points and help others
