Question about Maytag MAH6700AWW Neptune Front-Load Washer
Water Leaking really bad from the Dispenser area
When the machine is turned on and water begins to run inside after a few seconds water comes rushing out of the dispense area, as if it's clogged up.
  • 1 more comment
  • frontload Aug 21, 2008
    You guys Rock.. I'll tell all my family and friends to always check with this site before calling someone into there homes.. Thank you so very much for your help...
  • gobsmacked Oct 08, 2008
    My washer started leaking (fast trickle under the center of the door) about 2 wks ago. The repairman came and said it needed a new boot. The front of the machine was also cracking from the major shaking so that would be replaced also as well as taking it off of the pedestal since it is on the second floor. After he replaced the front the leak was gone and he just leveled it up and said to call if it leaks again. I should also say that he intended to replace the boot however maytag sent a refrigerator drawer instead of the boot! He finished up this afternoon and I washed my first load, i didn't even hear the spin cycle! I started another load and now i'm receiving an error that looks like tE. While I was looking up the error code online the washer was flooding the laundry room :( It is no longer a trickle it is pouring out the bottom of the door and the dispenser!
  • thmartin Nov 11, 2008
    My washer just started leaking from the dipenser drawer how do I fix it?
  • 3 Answers
Disconnect the plug from the outlet. Remove the top of the washer panel by removing the 2 back hex screws then sliding it back to lift it off of the washer. Take off the front control panel by removing the phillips screws holding it in place. Remove the dispenser drawer. Check the dispenser housing for clogs or lime build up at the bottom of the dispenser housing. Or the drain hose (large black hose attached to the front of the drawer housing) to the washer may be crimped or clogged.
Posted on Aug 19, 2008
    New Friend:
I set up a video to tape my machine and saw not a little spray but a steady flow of water coming out at the bottom of the soap tray. After removing the soap tray and taping a piece of plastic over the opening, I noticed that the spray of water which rinses out the soap tray was spraying on the plastic pretty hard and reasonably high. That is because the first set of holes have a little deflector on them directing the spray to the front (I guess to make sure the soap tray is rinsed out). I got a sharp chisel and carefully knocked the deflectors off. Now it sprays down and not out toward the front of the soap tray. I suspect that the nozzles were getting clogged (maybe from calcium) and shoot the water higher than it was supposed to.
No leaking yet.
Posted on Apr 07, 2013
The water dispenser is leaking
Is it a side by side? Did you change the filter recently? If so, Could be air bubble in water tank.
Mar 31, 2011 | GE Refrigerators
Whirlpool duet washer leaking badly. when it starts filling water rushes out of the detergent dispenser and the bottom of the door.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Apr 25, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
My washer is spewing water everywhere sometime during its cycle. The floor is soaked! It seems to be coming from the soap dispenser area. I cleaned the dispenser really well but still water everywhere.
The only way to determine where the problem lies is to take off as many covers as possible then run your usual wash cycle. The problem could be a leaking or blocked pipe or a rubber seal that leaks etc etc. Have somebody in the know open up your machine to determine where the leak comes from.
Best wishes,
Graemevm
Dec 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Drying cycle ma;function
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Water is leaking out of detergent dispenser- big time
Water pressure may be too high,try turning the cold water feed pipe (usually the blue one)down a little,not too much though.If this does not solve it,is the machine lying level front to back? If not pack up the front of washer until level.If still no good take out dispenser drawer completely check for obstruction inside housing of machine. Also while drawer is out clean the underside or top of dispenser housing with an old toothbrush or similar tool,(you will see several pin holes where the water comes out when filling).To take out dispenser open drawer fully and there should be a clip at top back of drawer that you push while pulling drawer at the same time.Hope this is useful to you.
Aug 24, 2007 | Haier XQG50-11 Front Load Washer / Dryer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
914 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
