Question about Braun Flex Integral Shaver 5520
Braun 5314 battery is shot but should the shaver still work on the mains.?
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
  • 164 Answers
SOURCE: how to change batteries braun shaver ?
It is suppose to be rechargeable and have a 2 year waranty on it. send it bback and get a new one or just take it apart and use regular batteries.
Posted on Aug 29, 2009
SOURCE: braun 7570 shaver wont charge but wont run on mains lead
My Pulsonic Razor that I received for Christmas will not run on battery, or with the plug supplied. I have tried just about everything I can think of. Is there a way to solve this problem? I do not have a receipt as it was a gift and am quite certain it would cost me a small fortune in order to fix it at a Braun Service centre.
Please help me if you can. TY
jbabcock12@cogeco.ca
Posted on Aug 08, 2010
brector3
  • 1610 Answers
SOURCE: How do you open a
You will find replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Start by removing the foil and cutter. Then remove the swivel frame by removing the two tiny screws on each side of the inside of the swivel frame.
To open the shaver you will first need to remove the two round screw covers on the bottom. Then remove screws. You can then gently pry the two halves apart from the bottom
Posted on Sep 30, 2010
Testimonial: "Thanks a lot. The tip was super and my shaver is again working fine."
brector3
  • 1610 Answers
SOURCE: Braun Synchro 7526 Electric Shaver How do I open
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will also find compatible batteries at the link below
Posted on Nov 28, 2010
My braun 5314 does not switch on
Most likely, the battery needs to be replaced. Compatible battery type can be found at shaveroutlet.com
Shaver Replacement Battery AA NiMH
Jul 04, 2015 | Braun Flex Integral 5314 Electric Shaver
Where in Australia can I buy a foil
You can purchase a new foil for Braun model 5314 at shaveroutlet.com and have it delivered to your mailbox in Australia. See link below to webpage
http://shaveroutlet.com/shaver-replacement-parts/braun-5000-6000-series-flex-integral-flex-xp-foil-p-350.html
May 06, 2011 | Braun Flex Integral 5314 Electric Shaver
My battery is so shot that it will hardly run on 110 AC anymore - takes it hours just for it to run. How much to get this razor refitted with a new battery?
You can do it yourself if equipped. First, remove the foil and cutter. Then remove the swivel frame by removing the two tine screws, Next, remove the two scew covers on the bottom. These are found on either side of the plug recepticle and look like part of the trim. You can pry them off with a small flat jewelers screwdriver or similar. Remove the screws underneath. You can then gently pry the front of the case off from th bottom. Once case is removed, you can lift out the circuit board to access the battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find compatible battery type at shaveroutlet.com. See link below
If this is not something you can do yourself, shaveroutlet.com can do it for you. See info and ordering at the link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 13, 2011 | Braun Flex Integral 5314 Electric Shaver
Braun shaver 5314. The green light works when plugged in. Does not hold charge to work at all. What is the problem, can it be fixed or should I begin looking for a new shaver?
Battery is dead. You will find compatible battery type at shaveroutlet.com. See link below
Remove foil and cutter. To open the shaver, pry off the two screw covers on the bottom and then remove screws. Remove the swivel fram on top by removing the two tiny screws. You can then gently pry the two halves apart from the bottom. You will be able to access the battery pack once the case is seperated
Dec 28, 2010 | Braun Health & Beauty
How do you open a Braun 5314 Shaver to replace batteries?
Sep 30, 2010 | Braun Flex Integral 5314 Electric Shaver
Braun 7570 shaver wont charge but wont run on mains lead
Mar 14, 2010 | Braun 7000 Series Foil and Cutterblock
The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Feb 03, 2010 | Braun Health & Beauty
How to replace the battery in Braun Model #5314 shaver
remove shaver head (2 screws)
remove 2 screws at the bottom of unit.
with coin, turn plug socket.
now pull carefully cover.
you'll need a welder to replace the 1.2v nimh rechargeable battery.
May 03, 2008 | RIM BlackBerry Pearl 8100
Jun 10, 2007 | Braun Flex Integral 6520 Electric Shaver
Health & Beauty Logo
105 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
