Question about Lexmark Optra T610 Laser Printer
PRINTER HAS A PAPER JAM ERROR 201, REMOVED PAPER NEXT ONE JAMMED THE SAME UNABLE TO GET IT TO PRINT WITHOUT JAMMING THE PAPAER
  • mirhom May 19, 2011
    changed paper didn't make any change still keeps jamming
  • mirhom May 23, 2011
    Have no diagnostic test menu.
    Genius:
  • 1,196 Answers
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. If problem still persist, you will need to replace the colored as well.let me know if additional information is required.
Posted on May 19, 2011
    Genius:
  • 1,157 Answers
Hi mirhom,
Error: "201 Paper Jam"; Paper jam is commonly caused by A5 paper; paper jamming directly after exiting the fuser. The solution for this is If you are using A5 size paper, make sure it is cut long grain.
"Grain" refers to the alignment of the paper fibers in a sheet of paper. Paper is cut either grain short, with the grain running the width of the paper, or grain long, with the grain running the length of the paper. The orientation of the grain contributes to the rigidity of print media and affects feed reliability.
Hope it helps.
Thank you for using FixYa.
  • Reynaldo Labaguis Jr.
    Reynaldo Labaguis Jr. May 20, 2011
    Hi mirhom,
    If changing paper did not resolve the problem this could be caused by a defective fuser exit sensor assembly. Try to enter the diagnostic tests menu, select Base Sensor Tests, select Output Sensor Test and check the fuser exit sensor for correct operation. If the test fails, check the internal fuser cabling, DC auto connect on the fuser frame, fuser DC auto connect to the system board cable, and the cable connection to J14 on the system board.
    You may also check the flags on the fuser. There should be two flags that stick up, one is the exit sensor, the other is the narrow media sensor. It is possible that one of them has popped out of place or the tip has snapped off of it.
    Hope it helps.
After any printing it say papaer jam. jam40
The paper feed path is not clear - remove any pieces of paper or debris if this doesn't help use dry paper because moisture can do this as well
Jun 25, 2015 | Office Equipment & Supplies
I keep getting a paper jam 201 every time I print. Then I have to open it up and take out the cartridge. What is causing the paper to jam?
A 201 paper jam error indicates the paper did not reach the fuser sensor within the proper time period. This usually indicates the fuser has a problem and needs to be replaced. The part number for the fuser is 56P1333 and it is user installable. You can get one from many places online such as Amazon.com
Aug 20, 2012 | Lexmark T630 Laser Printer
Papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
Apr 02, 2012 | Toshiba Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
My printer lexmark e342n 201 jam error code, what the are problem, fuser or pick-up roller and how to soft that problem. tq
If you are getting 201 error code, it means a paper jam has occurred. To fix this problem please Open the front door. Remove the toner cartridge and remove the jammed print media.
Click on the link http://bit.ly/p1jJcd to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Jan 22, 2011 | Lexmark E342n Laser Printer
Even after removing thye paper the status shows papaer jam. and unable to print
Try to use some compressed air, on the back inside of the printer, probably one of the sensors is jammed with dust or a tiny piece of paper.
Dec 05, 2010 | HP DeskJet F380 All-In-One Printer
We had a paper jam in our HP Photosmart C5280 Al-in-One printer. Error message in window reads: Carriage jam! Open door, clear carriage jam, and then pres OK to continue We opened door and even...
after closing the cover and removing the jammed papaer does it still says "paper or carriage jam"????
if it still prompts you that theres a jam and you've already removed it, try to turn off the printer, disconnect from its connections (pc and ivr or ups or wherever its connected) wait for like 5-10 sec then connect it again...
hope this resolves ur prob...
ive experience it to with my hp j3500 all in one... a paper jam, this is what i did and i think it worked for me... hope it do to your printer.. ciao!
Sep 10, 2009 | HP Photosmart C5280 Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Lexmark Optra T610 Laser Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
