Question about Cybex Topaz (Stone) Stroller
I have the cybex topaz 2009 and I would like to buy the new and improved canopy. Is there any way that I can buy the canopy and attach it to my 2009 buggy?
Tv won't work-weak or no signal
First check all of the connections, then check to see that it is in cable mode. If your machine is under a year old call cybex for a new TV. If not remove back of TV and check connections to coax port. If you have to order a new TV I would just go out and buy a regular TV and mount to wall as the TVs for this tread cost around $1000
Apr 14, 2014 | Cybex 750T Legacy Commercial Treadmill
Cybex 530t error 1
Error 1, Err1 Belt didn't start (or no speed sense) 1. Perform speed calibration procedure
2. Check speed sensor
3. Check motor brushes
4. Check drive motor
5. Check lower board
I am attaching a link for the service manual. This information can be found on page 65. You can use this manual to determine the steps required for checking the above mentioned items.
http://www.sportsmith.net/images/product_support/cybex/Manuals/Service/LT177304-CybexProPlusTreadmillOwnersServiceManual.pdf
Cybex Pro 530T Treadmill Parts Deck Belts Motor Rollers SPORTSMITH net
Apr 09, 2014 | Exercise & Fitness
Car seat adapter for Hauck stroller
HI,
Are you still looking for sun canopy for bee 2007-2009
I have blue for sale if you interesting please email me .
Thanks Oli
May 09, 2013 | Baby Gear
Cybex 445t err 1
Error 1 means belt didn't start (or no speed sense).
Speed sensor and motor brushes are usually the culprit. Most of the time this its just the speed senor is out of place. Remove the hood and next to the pulley on the front roller you'll see a little black pill with wire attached. Adjust the tip of that to where its sitting within about an 1/8 inch from the magnet on the pulley. Speed sensor can go bad and you can tell by using a voltage meter on the audible continuity setting. New speed sensor: Cybex CX 445T Speed Sensor Part # AX 21500
If that doesn't work check your motor brushes, continuity on communication cables and calibrate it. If that doesn't work you may have a much larger problem such as a bad motor. How to test your motor
Feb 07, 2013 | Cybex CX 445T Treadmill Deck
Canopy
no it cannot be replaced you have to buy a brand new one srry but have a nice day
May 14, 2012 | Jenn-Air JMC8130DDS Microwave Oven
The plastic part on side of stroller that attaches to canopy is broken. Where do I buy a replacement canopy or part?
I doubt that can be found as a part but plastic can be welded google to find a local plastic welder. If the plastic is black the repair will be almost invisible,
Nov 08, 2010 | Zooper Tango Twin Stroller
How to replace fuel filter on harley davidson 02 road king
I am having problems viewing the reply but if you have a FLHRCI then to replace the fuel filter you will need to be prepared to put some time into it.
First remove the console off the fuel tank, one nut below speedo and the phillips screw lower close to the seat. You will have a disconnect on the top left side of the fuel tank to disconnect. Then disconnect the vent tube from the tank with a gentle pull & twisting motion. Now the fun part there are ten torx T20 screws you need to remove, but first you must go buy new ones along with the gasket and fuel filter kit. DO NOT reuse the screws. Now for whatever reason they call this piece a canopy, go figure. Once you have your parts go ahead and raise the canopy slightly and twist it to the left a little. Now this can be tricky because there is a spring loaded hng to work here, be care not to over stress any thing. Then you can begin to pull the canopy and components from the tank. You will be limited by the convoluted tubes (hose) attached as to how far you can raise the canopy, if you remove one be careful as where they attach is plastic and breaks....easily sometimes, then you need a $350 part.
Next read and look at the diagrams that come with your new fuel filter to install it. Once done carefully reverse the canopy removal process and tighten the canopy bolts in cross pattern o somewhere between 18-27 in-lbs. Hope this helps.
JP
Jul 25, 2009 | 2002 Harley Davidson FLHRCI Road King...
Canopy broken on my fisher price stand and ride duo stroller
I have the same problem FisherPrice customer Service is useless. I would even buy a new canopy frame
Jun 01, 2009 | Fisher Price Baby Gear
Cybex Topaz (Stone) Stroller Logo
29 people viewed this question
Top Cybex Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Cybex Baby Gear Expert? Answer questions, earn points and help others
