Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
The center post of my refrigerator side by side where both dooes meet and close on is warm to the touch.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Posted on May 20, 2011
Seals on my beco are hot to touch fridge freezer feel warm
Almost the same post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
I have a Hotpoint CSX24GRXA side by side refrigerator. The freezer side started having cooling problems in that it would get too cold, so I adjusted the thermostat to warm up the freezer. Then, I noted...
ok one thing at a time . the center post that is hot is a sing that the coils need to be cleaned and that the compressor is running to hot . this will also cause over run times and this causes tempt problems . such as too cold for the settings . so clean coil and if it look good the you did a good job and ck the fan blads and clean them too . they can't run properly if dirty and out of balance . some warmth on the center post is normal but if very hot then thing are getting dirty .. hope this helps mm
Oct 06, 2010 | Hotpoint Refrigerators
Side of refrigerator getting really hot from top to bottom on freezer side about 1 inch from the door back. Also where the two doors meet in the middle, really hot. What can I do?
The unit has a auto defrost feature. Every six to eight hours these heaters come on to melt ice build up.The cabinet will feel warm to the touch during this cycle.If it is always hot, I suspect a stuck defrost thermostat
Nov 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Front center panel where doors meet to close are very warm/hot to the touch. Is this normal for this refrigerator?
yes they have heaters in them to help reduce moisture on the ref you can ussually turn them off by turning the energy saver feature on but this may cause moisture to build up on the exterior part and the inside of th ref
Sep 06, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ihave a Galaxy side by side and the center metal strip where the two doors meet and the magnets connect is very hot to the touch, any suggestions?
It's has to be warm to keep out the moisture, but not very hot .It will help if you clean (or blow out) the dust out of the coil in the back of the fridge (you'll see it at the bottom when you pull out the cardboard cover.Always disconnect the fridge before do any work.
Aug 06, 2009 | GALAXY Microsystems 25.4 cu. ft....
Center post on 11 year old side by side amana is hot
check the coils underneath the unit to be sure they are clean if they are clean then check the condenser fan motor behind the cardboard cover on the back of the refrig. the motor could be bad or has an obstructuction. good luck peyton
Jan 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The door seal contact surface is hot to the touch.
ther so pose to be a switc if none that for hummit
Jan 17, 2009 | Kenmore 53082 / 53084 Side by Side...
I was vacumming the coils under my whilpool side by side when I believe I heard a faint whistle along with a odorless thin white smoke that stayed low to the ground. The compressor is hot to the touch, yet...
yes it sound like you did puncture the refrigerant line to your unit, if you have a sorae refrigerator I would proceide in relocating the stuff and call a service company out to repair the leak.
Dec 27, 2008 | Refrigerators
Ge side by side freezer refrigerator
That is called a heat strip. Used to keep moisture down around the door gaskets. You will need to roll unit out, take lower back plate off and check to see that the condinser fan is turning when compressor is on. If not,replace fan motor
Jul 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
