Question about Cycling
Brakes need to be tighten - Cycling
    Problem Solver:
  • 10 Answers
The wound steel cable that connects your brake lever to the brake pads can be adjusted via a screw or nut at the top of the brake pad assembly. Simply loosen the assembly and gently tug the wire end toward the front of the bike tire to tighten brake grip; tug it backward to loosen. Tighten the screw partially to hold the cable in place, test the brakes with the brake lever, and adjust again if necessary before fully tightening. It may help to put the bike on a stand or hold it so that you can spin the wheel, check that the brakes are adjusted so that the pads do not rub the wheel. You can do the same thing with the rear brakes. You will need a small tool to loosen and tighten the brake pad assembly; your household toolbox should have something :)
While you are adjusting the brake tension you should also check the brake pads for signs of wear. If your bicycle brakes squeal, show uneven wear or are perfectly smooth, go to a shop and get a new set! Regular brake maintenance is very important for bike safety.
Posted on May 19, 2011
2003 PT Cruiser -Brake fluid is leaking on rear passenger tire where the brake line connects to the brake mechanism. Is it likely loose and just needs to be tightened up or should I replace the line?
-Put it in part position.
-Turn off the engine.
-Craw under neat where you can see the leaking area.
-Wear a safety glasses or goggle.
-Ask some one to help to press the brake pedal for you
and watch where is the fluid come from.
-If from the connector then tight it more. (Not too tight).
and try press brake pedal again. If there is no more leak
then you're good.
-But if it leak from the pipe instead at the connector then the pipe line might broke. Need new line.
Good luck
Mai
Feb 14, 2017 | Chrysler PT Cruiser Cars & Trucks
Parking brake will not keep car from moving.
May be the rear brakes need adjusting,or the park brake cable needs tightened. If you leave it in park ,running,step on the brake ,notice how far the pedal travels,then apply the e brake.Step on the brakes again,if the pedal is firmer,the rear brakes need adjusted.If there is no difference the cable needs tightened
Apr 05, 2014 | 1988 Oldsmobile Cutlass Ciera
I have a brake problem on my 2005 GMC sierra
I need to know if the brake pedal gets tight or does the brakes get tight and slow vehicle down as if brakes are being applied.....If it is just the pedal getting tight and hard you have a vacuum Brake Power booster problem....If the brakes are locking slightly this could be a few different things......NEED MORE INFO..and Mileage....
Apr 01, 2014 | 2005 GMC Sierra 1500 Hybrid
When I squeeze the rear brake level, both brakes come in against the wheel but when I let go, the left one stays against the wheel. I'm sure one of the bolts needs to be tightened just not sure which one.
Generally the problem is that the mounting bolt is loose and not holding the brakes in place.
You need a 5mm allen key to tighten the bolt. The bolt is located behind the brake and behind the frame or fork depending on whether it is front or rear. Hold the brake in place centered on the wheel then tighten the nut/ bolt with the allen key. test the brake, if it is still doing the same thing then there is an issue with the tension and you will want to run by a bike shop and have them take a look, it will be a quick diagnosis if the mechanic has any skill.
Jan 23, 2011 | Campagnolo Record Skeleton Brake Calipers...
Hand brakes are loose and need to be tightened so they will stop the bike. How do I tighten the hand brakes?
loosen the anchor bolt the hold both brake shoes against the wheel rim pull the cable tight and tighten the anchor bolt
Aug 07, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
Rear wheel (left) brake fluid leak
First of all determine where the leak originates. At the outset make a mental note that the brake fluid will need bleeding at some point since if the fluid can leak out it is likely that air can bleed in. Air in the brake fluid is to be avoided as it impairs good brake function. First of all get the whole area clean. Use a small wire brush to remove all loose corrosion. Now check that there is plenty of brake fluid on the reservoir container above the brake under the hood, top it up as needed. 1) Bleed screw : Have a friend apply pressure on the brake pedal and undo (yes undo) the bleed screw just a quarter turn. Release about a quarter of a cup of fluid and then re-tighten the nipple before (this is important) the pressure is taken off the pedal. Clean everything with a cloth and tighten the bleed screw no ore than an extra quarter turn if this was the source of the leak. Check by standing on the brake pedal. 2) Caliper union : The flexible hose screws directly into the caliper and if it is leaking at the caliper just give it an extra tighten and then carry out (1) above. 3) Pipe Union : the other end of the flexible hose goes through a bracket and connects with the metal brake line. If tightening here, hold the metal junction of the flexible pipe steady and then tighten the brake line union nut. Do not be tempted to just tighten the nut on its own as the junction is liable to rotate within the bracket. 4) Brake pipe : Most brake pipes are made of steel (??!!) which as we know eventually corrodes. Most corrosion of brake pipes occurs either at unions or at brackets where water and salt can get to work. The only recourse is to change the brake pipe for a new length. 5) Caliper body : the seal between the piston and the caliper cylinder can sometimes be compromised by corrosion. You will need to remove the caliper/slave cylinder from the car to carry out a thorough inspection.
May 25, 2010 | 2002 Hyundai Santa Fe
Need to tighten emergency brake on 1997 toyota 4runner
if you need to tighten the cable under the vehicle you will find where the single cable from the front connects to the two rear to tighten set the emergency brake six to seven clicks and tighten nut until the brakes catch. if you need to adjust the actually brakes in the drum set the ebrake the same setting find the little rubber plug on the backing plate remove get a small flat head screw driver and flash light find the little gear inside use the screwdriver to turn will only go one way turn the gear until brakes grab and wheel can't be turned.
Aug 30, 2009 | 1997 Toyota 4Runner
How are the front brake on a rebel adjusted
There should be a knurled barrel adjuster on the brake lever. Unscrew it some and your brakes should "tighten." When you have 'em where you want 'em, screw the lock ring (the big round thing on that barrel adjuster) back down against the brake lever, locking it in position.
If you can't get it tightened enough that way, you'll need to take slack out of the cable at the brake itself. Loosen the nut that holds the end of the cable in place and pull the cable tight, then tighten the nut back up. You can then fine tune using the barrel adjuster on the brake lever.
Jul 29, 2009 | Mongoose Bmx Bicycle Brake Lever Bike Part...
Tighten emergency brake
iit adjusts by the parking brake pedal
Nov 24, 2008 | 2005 Honda Pilot
Bicycles Brakes Tightening
Are the brakes center pull or side pull?
Center pull would have a nut directly in the center of the brake. Now go to the brake lever on your handle bars and tighten the turn screw where the cable handle is. Keep turning the nut till your brakes grip.
If you have side pull brakes. Then where the cable meets the breaks. Their is a nut that the cable slides through. Loosen the nut and firmly pull the cable till its tight and retighten the nut.
Nov 03, 2008 | Cycling
Cycling Logo
357 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
