Question about Acer Aspire 5100-3357 Notebook
I have a acer aspire 8930g. black screen constant except when i press fn +f6 when it comes on as normal very briefly
Geekman
  • 32281 Answers
SOURCE: Ihave an acer 9410Z laptop the backlight won't
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Jul 19, 2009
  • 23 Answers
SOURCE: Acer Aspire 3620 Screen
Check Acer's website for a BIOS update. I've seen a LOT of laptop's screen issues been related to the power saving settings in the BIOS. Sometimes screens going black very fast and not working properly can be caused by that.
The Power Inverter could also be the problem which you wouldn't be able to repair yourself. If you purchased it at Best Buy you can take it to them and they could get that fixed for you (at a charge if there is no warranty with that).
Posted on Jun 22, 2008
Solo4665
  • 53 Answers
SOURCE: My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Posted on Dec 11, 2008
SOURCE: Screen on Aspire 3000 is very very dim
Hopefully it is this easy. The Fn and left arrow combination should dim the screen. To brighten the sceen, try Fn and right arrow.
If this does not work, then try other combinations using your Fn key to make sure the Fn key is working.
Posted on Dec 19, 2008
SOURCE: black blank screen of my Acer aspire one notebook
See http://macles.blogspot.com/ . I had similar symptoms and shipped it off to Acer for repair and it was returned with new level of BIOS as only repair. The macles blog has directions/links for upgrading the bios on an apparently dead machine, if you'd like to try it yourself.
Posted on Jan 15, 2009
I have the acer aspire 5536-5112 black screen
I solve this using Fn + F6, using a 5536 model. Just press Fn + F6, keep holding it and hit the power button, wait for about 5 or 7 seconds, release the Fn and F6 keys. thank you so much guys!
Oct 19, 2012 | Acer Aspire Computers & Internet
My Acer Aspire 5315 has problems with the screen. It does not come when I press the power button. It stays off constantly??
Hello Guest,
Have you tried pressing the Fn+F6 keys together ? That keyboard combination is used to toggle the Acer Aspire 5315 screen off and on.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
May 13, 2010 | Acer Aspire 5315-2713 Notebook
No light on screen on acer aspire 5610
Hello pboppa1,
Have you tried holding the [Fn] key at lower left of the keyboard and pressing the [F6] key in the top row at the same time? The [Fn] and [F6] keys combination toggles the screen on and off.
Have a great day,
martyshaw152
Jan 06, 2010 | Acer Aspire 5315 Notebook
My laptop comes on everything lights up except the screen
it would be the blue lettered fn and f6 keys, hold fn key-then hit the f6 key to toggle display. otherwise try and reset the notebook- take out battery and unplug the unit. then push and hold the power button for 60 seconds. then put the battery and plug it back in, and try and see if that works. this has worked on my acer 5100 several times! the screen could have a problem also. this is what i worry about every time this happens 2 me. good luck! if i can help more reply.
Sep 02, 2009 | Acer Aspire 5100 Notebook
I have an Acer Aspire 8930G trying to connect to my TV with HDMI
After you connected the HDMI Cable to the TV...Did you press the FN + F4 Key on the keyboard... The first screen you will see is the notebook screen is blank and the TV has got the desktop on top of it...The second time you press the FN + F4 then you will see thedesktop on the notebook and as well as the TV...The third time you press the FN+F4 you will see the desktop on the Notebook...
Aug 15, 2009 | Computers & Internet
Battery or Screen problem
Solution? - not sure yet but having read solution by Hector_ahab, tried various F() buttons in conjunction with Fn button. Pressing Fn with F6 switches between black and normal screen on my Acer Aspire 5920. Fingers crossed!
Apr 17, 2009 | Acer Aspire 4520 Notebook
Black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Dec 30, 2008 | Acer Aspire 5100 Notebook
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
I think you're trying to output the screen to external monitor right ? So when you press Fn+F6 this will output to external monitor only but if you do it again it will output to both (External and you LCD) and if you repeat the step again you're back to normal.
goodluck,takecare.
May 24, 2008 | Acer Aspire 3610 Notebook
Acer aspire 3050 black
refer to ur user manual to see which key for brightness e.g.fn+f 9
(reduce brightness)if havnt got one can easily download one of net.try to swich screen to monitor.connect external moniter and press fn+f 5.(refer to manual maybe different key)
press down and release screen lid button see if any response.if all fail need to disassemble.
remove screw in about middle of pc underneath.this ia retainer screw for key board.remove screws dirrectly behind screen to remove plate with buttons.then can get access to keyboard and lift away (do not disconnect it just rest it on screen or front of pc )check cables from mother board to screen.check inverter.
all these are worth checking but initially sounds like inverter faulty.
Mar 05, 2008 | Computers & Internet
Acer Aspire 5100-3357 Notebook Logo
1,351 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
