Question about HP Photosmart C5280 InkJet Printer
I am getting an error message saying: error has ocurred in the script on this page. Can you recommend a fix?
  • maljkw May 22, 2011
    I have not been able to locate the Run button in order to proceed. Once I have clicked on Start, do I then go to the printer folder or should this Run button be in another area?
    Thank you.
    maljkw
    Genius:
  • 1,157 Answers
Hi maljkw,
Kindly try the following steps to resolve the error that you are getting:
1. First, go to Start.
2. Then, click Run.
3. Type in Regsvr32 ole32.dll.
4. Hit on Enter.
Please let me know what will happen. Hope it helps.
Thank you for using FixYa.
Posted on May 19, 2011
When I start magic desktop I get an error that says cannot run scripts on this page How can I fix this?
go into internet options from the control panel, click on advanced tab and reset browser settings.
May 20, 2014 | HP Computers & Internet
Tip
3 Quick Solutions to Repair Juno Webmail Script Error message
If you have an Ad-blocker or a popup blocker installed on your computer system, you may get many script error messages while connecting with the Juno Webmail. You can prevent these mistakes from encountering by configuring the pop-blockers / ad-blockers correctly. If you're often getting a Script error message whenever try to start Juno or log into the webmail account, then you will require configuring the ad-blocker programs to operate with Juno webmail; otherwise, you may face the Juno sign in problem. There are three methods to do that:
    1.Add Juno Mail to the exclusion list of your ad-blocker
    2.Set up the ad-blocker to enable banner ads
    3.Disable the filtering feature in the ad-blocking program If you're using the AdSubtract tool, you should follow the instructions given below. In the case of any other pop-up blocking or ad-blocking software, refer to the documentation of your blocker tool for the accurate guide on configuring the software to enable ads from Juno Mail. You can get connected to the Juno webmail support experts and solve these error messages in a proper manner.
    Solution 1 - Insert the Juno Webmail to the Bypass Site list
    If you want to add the Juno website into an exclusion list, right-click anywhere on the web page and choose the 'AdSubtract: Bypass Site' option. You may require repeating this procedure on other Juno web pages on which you get the script error messages. On the other hand, speak with the Juno professionals to repair your email account issues.
    Solution 2: Configure AdSubtract to enable banner ads
    This solution will fix the script error messages that can prevent you from accessing your Juno email account, but will also cause in other banner advertisements showing on other websites you access.Here's how to setup AdSubtract software to allow banner ads.
      1.Launch the AdSubtract program and click on the 'Block' icon.
      2.Deselect the Banner Ads field from the selection on the left.
      3.Click the 'OK' button to save and apply the changes. If this workaround doesn't work and you're still getting the script error messages, then either you can get in touch with Juno customer care executives or go to the next.
      Solution 3: Disable AdSubtract tool filtering
      This workaround not only resolves the script error messages for the Juno webmail site but also causes in disabling all of the AdSubtract's filtering efficiently.
        1.Launch the AdSubtract tool.
        2.On the main dialog window, click on the 'Disable Filtering' option under the 'Ad Blocking' section.
        3.Click the 'OK' button to save and apply settings. However, if you still have any kinds of technical issues with your Juno email account, or continue to face the script error even after attempting all these solutions, or any further queries, it's highly recommended to call on the Juno webmail support phone number and ask the help to solve all Juno-related issues within a short span of time.
Juno Customer Support Phone Number
on Apr 11, 2017 | Miscellaneous
A message keeps showing up when on internet explorer on facebook that says, a script on this page is causing internet exploer to run slowly if it continues your computer may become unresponsive i have...
Try this.
Common script errors messages can be eliminated by Clicking:
1. Open Internet Explorer.
2. On the Tools menu, click Internet Options.
3. In the Internet Options dialog box, click Advanced.
4. Click to select the Disable script debugging check box.
5. Click to clear the Display a notification about every script error check box.
6. Click OK.
There are situations when a Web page contains script that takes an unusually long time to run.
There will be a warning message after a certain number of statements has been processed.
The solution is to increase the default number of statements,before the warning is given
1.Go to Start/Run/type :regedit
Open this key: HKEY_CURRENT_USER\Software\Microsoft\InternetExplorer\Styles
(If the Styles key is not present, create a new key that is called Styles.)
2.Right click anywhere in the right pane and create a new DWORD value called "MaxScriptStatements"
(copy and paste that in to the name box) and set the value to the desired number of script statements.
Try 8,000,000 to start with.
Be careful editing the registry.Back up the key first.
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Sep 21, 2011 | Microsoft Windows Vista Home Premium...
I get a message saying "an error has occured on
There is nothing you can do - the page in question has been coded incorectly. If you want you could contact the owners of the site in question and tell them about the problem, they are the ones that can fix it
Jul 01, 2011 | Dell Vostro 230 PC Desktop
Internet Explorer Script error
You may have scripting disabled in your Internet Explorer.
To enable scripting:
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE
Still not working ? Update software
use the links on this page to help update software.
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
Dec 07, 2009 | Yahoo Messenger
Error message when accessing internet explorer on the computer
This happens on installing vista the first time If u can install despite this message(ignore), then restart in safe mode and if your Vista is genuine then ask microsoft to send this particular file(SHELL32 if I h'nt forgotten) replace where the original is supposed to be and after that it should be fine. The Only other option is to Install WinXP_SP3 & enjoy.....sodeep
Mar 20, 2009 | Dell Inspiron 530 Desktop Computer
Http://db2.t.msn.com/en-gb/home.aspx?ver=8.5.1302&did=1
First let me explain. Each browser handles scripts (the stuff that make up web pages and stuff) differently. You have Notify Me of Script Errors turned "ON" on your computer, so you will be notified of every error or warning - even if it works fine.
FIX: To fix this, Go to your Control Panel (START > Control Panel) and, in Classic View (you can find that on the left panel), click Internet Options. In the tabs on the top, click "Advanced", and then find the category "Browsing". CHECK "Disable Script Debugging (Internet Explorer), and "Disable Script Debugging (Other)". UNCHECK "Display a notification about every script error".
Click OK, and then messenger should work fine. If it does it again, restart your computer, then it will work fine.
Nov 26, 2008 | Microsoft Windows Vista Home Premium with...
The Weather Channel Desktop
Go here and re install if you had the paid desktop
The error is caused by the proof of purchase file being corupt or missing.
If you are refering to the free vista side bar gadgets go here
Please rate this a fixya
Nov 08, 2008 | Lenovo ThinkPad T61 Notebook
When visiting a site such as Friends Reunited I cannot view the site as I keep getting a message up with a yellow exclamation mark in a triangle saying: Error in addLoadEvent:(object error). I have typed...
It appears to be a Java script error.
The chances are some pages your are visiting are using Java script to deliver multilayer messages or adverts.
If you didn't have Java script installed on your machine you would get an error along the lines of "page was unable to load" so I am guessing your Java script needs updating.
Go to this site: http://www.java.com/en/ you can either download Java or have the site check your computer to see if it has the latest copy(easiest method).
Aug 12, 2008 | Computers & Internet
HP Photosmart C5280 InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
