Question about Canon PIXMA MX850 Multifunction Printer
The paper feeder isn't working for the scanner...
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
Try re installing the software.
Posted on May 19, 2011
Toshiba e-studio 3510c
Check that the cable that comes out of the back of the feeder is plugged in completely. If not, turn off the machine and unplug the copier before plugging the adf connector in, then turn machine back on.
If that is not the problem, the sensor flag or sensor may be out of place. Where the paper goes in, there should be a black plastic flag hanging down that the paper will move when you insert it, If you can see it and it seems to move properly, then the sensor may be out of place or the sensor/feed medchanism is out of place and it is a little tricky to explain here. The sensor is above the flag, but under a metal plate and you may mess it up worse by trying to take it apart.
Nov 19, 2011 | Toshiba E-STUDIO 211C Copier
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
There is something preventing the printer to grab the paper to keep it from printing. I have checked to make sure that nothing is inside there, and there isn't. It rolls like its going to print,...
Try to remove the sheets of paper from the feeder. If you are physically able and willing, carefully turn the printer upside down. Any foreign objects or debris that may have accidentally fallen into the feeder should just freely roll out of it. If feeder is clear, place the printer down. Open the printer cover and make sure the paper path in the cartridge area is free from obstructions. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reload some paper and try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 26, 2011 | Lexmark X1270 All-In-One InkJet Printer
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
At scaning time show
Hi
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Feb 19, 2009 | HP Scanjet 7800 Pass-Through Scanner
Hp scanjet 7650 document feeder is not working
did u buy cheaper paper that will do it tease the sensor in it sumties try to dl latest driver form hp.com ok remove old 1st
Oct 09, 2008 | HP ScanJet 7650 Flatbed Scanner
Paper feeder
Check the paper fed tracks- make sure there are no debris in the channels. Can you hear the feed system working or is it not running?
Jun 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA MX850 Multifunction Printer Logo
old marine
old marine
