Question about Bissell 3750 Lift Off Bagless Upright Vacuum
Hi the foot pedal (button release) has broken on my Bissell lift-ogg. I have bought a new part but I am struggling to see how to fit it. any help would be appreciated thanks
SOURCE: Bissell 1950F Wet Pick Up Vacuum Cleaner
Dear Schonaldo, Thank you indeed for your reply. I phoned Bissel to locate a service centre close by as I did not have the expertise to do any repairs. The Bissel call centre referred me to their in-house service people who confirmed your finding that the machine is gravity fed, however they also suggested that sometimes there is a problem because of an air lock. Their suggested solution was to fill the tank and depress the trigger a few times and, if this did not work, to hold the trigger down for a period. It took me a day or so to get back to the machine and it could have been that the air lock was dispelled by time, however, when I re-filled the tank and depressed the trigger everything started working again. I wonder also whether I may have put too much cleaner solution into the tank, which may could have further exacerbated an airlock situation. Alternatively, I notice that the air vent at the top of the tank is very small and I have inserted a needle to open it up a little, thereby creating more pressure. Anyway hoorah - everything is working OK.
Posted on Sep 01, 2007
reddevil6
  • 1673 Answers
SOURCE: Broken handle release
Most times they don't break, it is the 2 screw holes at the back that back and the top will raise up from the base. If this is the case, remove the 2 screws and install longer ones with a flat washer on them to fashen down the top. But first the top will have to be removed to put the handle release in the right spot. You would probably look at around $60 to repair, unless the top needs replaecment, then it would be more parts.
Posted on Apr 15, 2008
Agent Don
  • 310 Answers
SOURCE: Foot pedal broken
http://geeksquad.fixya.com/ThreadView.aspx?prdid=49977&thid=629933
Foot pedal broken
Posted by Monte79 on May 28, 2008
I have Bissell Power Steamer Clear view IIII #3105403. I let someone borrow it (mistake #1) and he over extended the foot pedal that angles the upright during use. The pedal is still connected, but the power steamer is locked in the upright position. There is also a bit of dirty water in the bucket, and i cannot empty it because it's basically locked in now. HELP
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem with your Bissell, it sounds like he bent the handle release lever and you either need to bend it back or replace it depending on the level of damage to the item. Please feel free to contact the Bissell factory to see the best way to fix the problem, it is not an expensive fix however so contact your local vac dealer or get a referral from the Bissell factory for the nearest Bissell authorized dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
SOURCE: Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Posted on Jul 06, 2008
SOURCE: the foot release latch has broken or become unlatched on my uprig
I had this problem once before. The only thing I did was loosen the back 2 screws, take the release latch and just play with it until it catches, rea simple.
Posted on May 11, 2009
Handle won't catch
Hi Robert! Sounds like the handle release pedal may be broken. You may want to have a Qualified Tech at one of our Authorized Service Centers inspect your vacuum.
Here's a link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 04, 2013 | Bissell 3920 Bagless Upright Vacuum
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
Hi, pressing the big red foot button on the dc25 lowers the cleaner to the working position,but it wont stand up again. would appreciate some help. thanks. TC
sounds like the ball cradle is worn out, the springs are too stretched to pull the handle release pedal back into place. you can do one of two things, replace the cradle assy, or just lift the red pedal up when you raise the handle
Feb 27, 2010 | Dyson DC25 All Floors Bagless Upright...
Foot operated release "spring" is broken. Replaceable?
Remove the pieces of the old spring and take it to any OSH store, they have an assortment that will likely have one that will work.
Oct 20, 2017 | Bissell 3590 CleanView Bagless Upright...
The foot release latch has broken or become unlatched on my uprig
Mar 19, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Foot Pedal Broken
For the handle release, part number is Detent Lever 2030052 Try bissell.com, or call a local repair shop, if they repair Bissell's, then they may have this part in stock. You shouldn't have to take it aprt, there 2 tabs on the release that fit into slots on the base, there move the slots so as to release the tabs.
Jun 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Foot pedal broken
Foot pedal broken
Go Ahead. Use Us.
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
146 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
