Wvd24520eu/01 washer-dryer, bosch maxx 5, F17 error, does not dry washing, lack of tension on the heater dryer
4 Suggested Answers
SOURCE: i need a manual for my maxx 6 bosch washing
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Go to this link. Just downloaded one for my Maxx7
Posted on Oct 03, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
Bosch washing machine error code f17.any solution ?tks
The F17 error code is generated by the computer when there is a problem with the water supply.
Check to see if any of the valves are shut off or the filters on the hoses or where the hoses connect to the washer are blocked or restricted. Clean if needed and try it again.
If all that checks out, then you have a problem with the inlet valve on the washer, where the hoses are attached to the back of the machine.
Aug 22, 2016 | Bosch Washing Machines
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
I have a Bosch exxcel washer dryer.It does washing and clothes still soaked wet after finishing.When turning dryer on it gives error f17...Please can anyone help as I dont have manual.Thank you in advance.
F17 is water not coming into the appliance . if the appliance is ok when you use the wash cycles the fault will be with the valve on the drying cycle or your pcb . your inlet valve is a triple valve . 1 for the main wash and 1 for the pre-wash which are used for your wash cycles .the third one is for the drying cycle . it uses the water to condense the steam on the drying cycle . unplug the appliance . remove the lid . the inlet valve is at the back right . the far left one is the drying valve .It is more common that is at fault than your pcb . The only way you can be sure is with the use of a multimeter . you can do this with the power off .if you have access to one remove the 2 connections and measure the continuity (ohms ) across the two points . if it is open circuit ( no reading ) then that part of the valve is faulty . be warned though , this part can still be faulty even if you have a reading . if you or someone you know is competent with using a multimeter you can re-connect it then turn the appliance onto the drying cycle and see if you have voltage to the part . all that said if you lack experience fit a new valve . it is quite a common fault .
Nov 08, 2014 | Bosch Dryers
Lint clothes washing
this grease from the bearings
the problem is more likely to be the bearings
does it sound loud in spin
Jan 31, 2014 | Bosch Washing Machines
F-03
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
Jun 21, 2011 | Indesit W 123 Front Load Washer
Washing Machines Logo
835 people viewed this question
Top Washing Machines Experts
